C63 AMG (W204) 2008 - 2015
C63 Coolant Temp Fluctuating
Old Mar 20, 2021 | 08:00 PM
magnetiteblack's Avatar
C63
Hi Everyone!
Just wanted a bit of advice - owned my C63 W204 a few years now and ran into an illuminated EML a couple months ago. Code: 0856 "Coolant temperature is below thermostat specified temperature".
Changed Thermostat, radiator hose seal and flushed coolant. Test drove 400-500 miles no issues temperature needle steady & AMG cluster was showing 91-94C depending on driving conditions/weather (as was the case before the change).
Fast forward to few days ago - I'm finding the following:
Motorway 70mph+ = Coolant temp drops to around 82C (needle drops to 80 mark)
Standstill traffic or up to around 30mph = Coolant sits around the usual 93-94C
HVAC works perfect no heating issues
NO EML illuminated
Is this another failing thermostat? The Mercedes specialist SPR AUTO's in Stockport I purchased the Genuine Part from state this above is completely normal in the current UK weather but I haven't received the same information from a Mercedes Technician.
Look forward to any help/advice.
Thanks,
Old Mar 20, 2021 | 09:32 PM
deadlyvt's Avatar
2010 C63 AMG
Totally normal, your thermostat may be stuck open which is getting you that much lower freeway temp. If that’s the case the car will take longer to get to operating temperature from startup and throw a code. I wouldn’t sweat it unless it throws a code and even then it’s not the worst or most immediate type of repair you would need to do as it’s simply overcooling the engine.
Old Mar 21, 2021 | 06:17 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Don't think over cooling is a good procedure. Modern engines specially MB ones like to run hot and with proper pressure building in the system the water can get much hotter before doing any issues. Just my 2c though.
Is the cooling fan running when highway driving perhaps? This could give a cooler than normal temperature. Dodgy temperature sensor?
Old Mar 21, 2021 | 02:50 PM
Nathan Grimmer's Avatar
Originally Posted by magnetiteblack
Hi Everyone!
NO EML illuminated
Thanks,
Not sure if this helps, but mine is doing the exactly the same thing, and I deffo know my thermostat is fault from a visual inspection, just waiting for a new one to arrive, but the car does what yours is doing, my did throw a fault code also the other day, related to the stat. You can normally tell as it takes longer to get up too temperature
