C63 AMG (W204) 2008 - 2015
C63 only made 444whp??
Old Aug 13, 2021 | 03:43 PM
Guidonick's Avatar
2011 Mercedes c63 amg affalterbach edition
Originally Posted by hachiroku
lol, i looked and yes..i know nothing about Canada it seems. ha ha.
in either case...rod bearings don't tick, and if you had an issue with your main bearings you would have had a seized engine by now. my only thoughts are maybe its your oil pump, but if it was...you would have had an oil pump failure by now. i guess if it hasn't gotten worse and you can't identify, i guess ignore it?
I've got the engine rebuilt already. Everything is good now
Old Aug 13, 2021 | 11:42 PM
roadtalontsi's Avatar
10 C six trizzle
Since no one really mentioned this I'll just throw out. Maybe the 5XX WHP mega super duper tune was on race gas? who knows man. 444whp is plenty acceptable if you haven't gathered that by our sarcasm. Go race the car, does it feel good? is it quick? stage 2 should be a 11.5-11.8 1/4mi time if you can get off the line well. MPH is the biggest indicator of power as well. Dont get stuck on dyno numbers they are ultimately irrelevant. No stage 2 only n/a m156's are making 500whp on pump gas period, unless you live in dubai or at the race track where they sell 100+ octane.
I dyno'd a c63 a few weeks back and calibrated the rpms wrong... it rev'd to 18,000 rpms f1 style according to the graph lol. Remember things can easily be manipulated.
Old Aug 14, 2021 | 02:12 AM
Panzerbiscuit's Avatar
C63 AMG
These engines are pretty "noisey".
I replaced my lifters with the lifters from the sls bs, and the cam adjusters with a set of rebuilt and lightened units from 63motorsports. I never had any decernable ticking or noises to indicate that they were worn and needed changing. Just did it for piece of mind and as preventative maintenance.
Now, i can hear a very slight mechanical noise, almost like the cam chain operating. Doesn't sound sinister or untowards. Car runs flawlessly. I think it may be a factor of the lightened cam adjuster assembly and the motul 300v oil which is basically **** thin.
Old Aug 15, 2021 | 04:21 AM
Guidonick's Avatar
you know what's funny I just got home from the runs tonight (street drag racing) and I raced a pro charged 370 nismo he said he dynoed at 550whp and we did a roll from 60km/hr
and we were neck and neck and I ended up pulling on him top end. I was so surprised because he had 100whp more then me and also a lighter car. I guess dyno numbers don't really mean anything.
Old Aug 15, 2021 | 12:42 PM
10 C six trizzle
my blown 530whp has magically hung with much lighter 600whp + dyno'd cars. It's just a dick measuring contest most of the time. I remember seeing a twin turbo viper with a 650whp dyno sheet at a car show. I laughed so hard, there is no way it wasn't 1000whp+. That's just for the hustling they're going to do later.
Old Aug 16, 2021 | 02:30 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
just show them your dyno sheet when you race them for $$$. lol
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 18, 2021 | 04:58 AM
  #32
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
Originally Posted by BLKROKT
If everything checks out on engine - compression, leakdown, etc - I wouldn’t be too concerned about dyno numbers. They literally mean nothing without the baseline figure, ideally on same dyno same conditions same day.
With that said I would talk to your tuner, see what they think and if the file needs to be tweaked or not. Will likely have to datalog to get to the bottom of it, looking at AFRs, air flow, etc. I had to go back and forth with my tuner a dozen times before my headers file really ripped. Then a dyno tune gets you even more on top of that.
I’d also chat with Barry to see what he thinks.
Just to go off topic a bit, but what is your trap speed with full weight and street tyres (if you have any runs on street tyres)?
Old Aug 19, 2021 | 12:46 AM
  #33
cskalski's Avatar
2020 Camaro R/S SC (supercharged V6)
Rebuilt by who? Top end low end or complete? Either way that is a 500 hp motor sae net
Maybe the same amount of Torque as well? Looked good to me.
Old Aug 19, 2021 | 12:50 AM
  #34
Guidonick's Avatar
complete engine rebuilt top to bottom. By velocity autotek in bolton Ontario Canada
Old Aug 20, 2021 | 12:57 PM
  #35
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I haven’t drag raced for years bud. Last time out sometime in 2017 I snapped an axle and was done with it. Was normally in the 122-123mph range with a couple of 124.5x outliers. On street tires and in a much lesser state of mod and full weight. I imagine I would be in the 126’s now with more HP and about 600# less weight but who knows.
Old Aug 23, 2021 | 03:54 AM
  #36
swedepat's Avatar
2011 C63 AMG, 589hp
With street tires mine traps 124,74mph
Dynoed 569hp
Extra weight in rear(stereo)
