C63 AMG (W204) 2008 - 2015
My oil temp fluctuates between 105-120 Celsius, is this normal?
Old Aug 17, 2021 | 09:52 AM
rovis77's Avatar
C63 AMG
Hi everyone, I have a C63 AMG 2013 and my car´s temperature fluctuates between 105-120Celsius in normal driving without pushing the car. When it reaches 120C it starts descending, I guess the fan kicks in. Is this normal or it is running too hot?. Should I check the oil temp sensor, fan or oil cooler?
Old Aug 18, 2021 | 03:21 AM
sskhaliq's Avatar
C204 C63 (P31)
Are you referring to oil temp (digital gauge in speedometer)?
Mine stays around 105-106C, but weather here is on the cool side (15-18C)
From what I've seen from other posts, it could be due to hotter climate or driving hard - either?
Old Aug 18, 2021 | 03:46 AM
swedepat's Avatar
2011 C63 AMG, 589hp
Quite high i must say.
Mine is going between 96-101 degrees.
As i understand there are some problems with the thermostat, and there is an another one in cars sold in arabia.
check that up!
Old Aug 18, 2021 | 09:12 AM
Nukleuz's Avatar
C63
I have had my car for about 4 months now, for the first 2 months it was running about the same as you, touching 116 degrees on
hard bursts. I got advised to change the oil, which is what i did, it now doesnt go above 106 no matter how hard i push
Id recommend starting there
Old Aug 18, 2021 | 09:28 AM
rovis77's Avatar
C63 AMG
Hey man thanks for the advice!. What oil are you using now?
Old Aug 18, 2021 | 09:55 AM
Nukleuz's Avatar
C63
I'm running 5W-40 , but mine has very low KM ( 38,000 ) , not sure if that influences what oil you should use. Maybe one of
the more clued up guys here can advise.
Old Aug 18, 2021 | 10:01 AM
rovis77's Avatar
C63 AMG
My car also has low mileage 42,000 km. I will change the oil as you say to see if the temperature cools down
Old Aug 18, 2021 | 01:32 PM
swedepat's Avatar
2011 C63 AMG, 589hp
yes, oilquality has a big part in this.
My car when i bought it had 0w-40 castrol edge
i hit quite hig temps, above 110 when driving hard.
Now i run Fuchs Titan GT1 5w-40 and got temps stated in last post i made.
Old Aug 18, 2021 | 02:29 PM
Cammer88's Avatar
E63s
My car runs hot as well. I’ve been running Rotella T6, seeing anywhere from 105-117c. I recently switched to Molygen in hopes that it might cool down but it’s the exact same.
Old Aug 18, 2021 | 03:36 PM
rovis77's Avatar
C63 AMG
What oil do you recommend for me?
Old Aug 19, 2021 | 02:01 AM
swedepat's Avatar
2011 C63 AMG, 589hp
The one i run on, i wrote in the post you quoted
One of the worst thing one can do is running a fullblown race oil like Motul 300v
They aren´t good for road use.
Trackday yes.
This because they don´t have the additive package needed for 'longterm' usage.
Lubrication is superior though, as long as the oil is 'fresh'.
Old Aug 22, 2021 | 08:09 PM
rovis77's Avatar
C63 AMG
What brand of oil are using man?
Old Aug 23, 2021 | 07:05 PM
sskhaliq's Avatar
C204 C63 (P31)
Same here. I havent seen more than 106 on mine either.
I use Mobil1 Formula M 5W40
