C63 AMG (W204) 2008 - 2015
Connecting a Ctek MXS10 to my 2014 C63
Old Aug 30, 2021 | 05:41 PM
Ashley Mason's Avatar
2013 C63 507 edition
Hello everyone.
Im looking at buying a new charger as I'm sick of my battery going flat when the car is not in use.
Has anyone used and installed a Ctek MXS10 charger before?
Do you connect it directly to the battery? or do you need to connect it from the front of the car? all the info I find conflicts itself...some say you MUST install it in the front as there is a charging ecu that monitors voltage and if you connect it direct to the battery it misses it...is that true?
Any advice would help as I don't want to then be landed with an expensive bill to fix it
thanks!
Old Aug 30, 2021 | 05:49 PM
markov77's Avatar
2014 C63 AMG 507
I do it in the front, the owner manual even says that.
Old Aug 30, 2021 | 05:57 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I connect my Ctek 7 to the front connections and just leave until next time I use the car.
Because my garage is so small I regularly have to start my car several times to move it in and out with out actually driving any where.
Old Aug 30, 2021 | 06:43 PM
Thanks for that, so sounds like most connect it to the front opposed to straight off the battery
Old Aug 30, 2021 | 10:28 PM
deadlyvt's Avatar
2010 C63 AMG
Mine I added the quick connect fitting and have it connected right to the battery
Old Aug 31, 2021 | 01:44 PM
DRBC43AMG's Avatar
Same as me
