C63 AMG (W204) 2008 - 2015
Replacing pulleys
Old Oct 8, 2021 | 07:41 PM
skullbox15's Avatar
2014 C63
Replacing pulleys
I'm going to replace the pulleys on my 2014. How long should this job take? Any gotchas getting the fan tray out? Do I need to move the power still fluid container?
Old Oct 11, 2021 | 05:26 AM
Trav63's Avatar
Mercedes Benz W204 C63 AMG | CLA45 AMG
easy job buddy, did mine 2 months ago whilst replacing the radiator as a 'while I am in there' job, allow an hour to do the pulleys, fan is just clips and wiring harness toward the bottom of the shroud, no need to remove power steering resevoir.
completed job
Old Oct 11, 2021 | 08:44 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Agreed, pretty easy, you can do it with the fan on but it is easier and probably faster just to take it out, worst part is getting the pulley covers off the pulleys that have them when the fan is in, otherwise it is a breeze,
Old Oct 11, 2021 | 09:45 AM
skullbox15's Avatar
2014 C63
Thanks for the input guys! I just did my injectors this weekend. Took me 2.5 hours with 45 minutes talking my neighbor who has an E63 (M156). He stopped by when he saw I had the hood up. Our wives think we're idiots.
Old Oct 11, 2021 | 09:46 AM
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Pretty straight forward install, I did my UPD underdrive crank pulley while I was in there. Definitely remove the fan before attempting the install.
Old Oct 11, 2021 | 07:46 PM
Boostaholic84's Avatar
2012 C63 AMG P31 Coupe
At what mileage should these pulleys be replaced?
Old Oct 11, 2021 | 09:02 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
remove the fan...don't need to touch power steering.
whole job should take less than 2 hours. if you've done it before, you could get it done in 30-45 min.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Oct 11, 2021 | 10:13 PM
Top Answer: 1
seems it can be all over the place but have seen these bearings in these pulleys fail as early as 30k
Old Oct 11, 2021 | 11:02 PM
Panzerbiscuit's Avatar
C63 AMG
Mine seemed fine after ~120k kms. Replaced with billet pulleys for my peace of mind whilst my engine was having some work done.
Old Oct 12, 2021 | 02:28 PM
hachiroku's Avatar
SPONSOR
i've blow up my factory pulley's at 15k...i drive hard.
i've seized up the bearings of aftermarket pulley's at 30k...they use subpar bearings and aren't meant to handle the RPM ranges of our high reving V8.
some have gone 100k without failure with their pulleys...they probably have never gave it more than 30% throttle.
__________________
-BARRY
Old Oct 12, 2021 | 03:26 PM
12C63's Avatar
2012 C63
Very easy. An hour tops. Even torqued them.
I left my fan in, and suggest doing the same.
Why add extra steps?
Old Oct 12, 2021 | 04:41 PM
skullbox15's Avatar
2014 C63
I'm at 70k on my C63. One of my pulleys seized on my C32 and caused a bunch of other problems. Figured I'd do this before one locks up on me. It's hot here and I get on it.
Old Oct 12, 2021 | 06:14 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You the original owner? Freak of nature if your OEM bearings lasted that long.
Old Oct 12, 2021 | 08:28 PM
C63 AMG
Nope, from what i can tell im the third.
The two previous owners were very elderly gentleman.
From the service records, it seems like the the injectors weren't changed either until i had them done at the same time as the pulleys.
Old Oct 13, 2021 | 01:20 PM
TheMirror's Avatar
Is it correct to assume these kits from FCP Euro have everything one needs to freshen pulleys? Any difference between the Hutchinson and Gates kits, or is there another supplier that has superior quality? Weistec does billet aluminum ones, not sure if that is necessary for a car that will remain stock.
https://www.fcpeuro.com/Mercedes~Ben...&b=5&d=1056&v=
https://www.weistec.com/billet-idler-pulleys.html
Old Oct 13, 2021 | 01:49 PM
hachiroku's Avatar
SPONSOR
Gates is OEM, Hutchinson is just a good. Looks like Gates is cheaper, go with Gates.
__________________
-BARRY
Old Oct 13, 2021 | 02:57 PM
TheMirror's Avatar
Ah good info, thanks for that.
