C63 AMG (W204) 2008 - 2015
help with timing cover removal..and part #
Old Mar 13, 2022 | 07:10 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
Hi guys
taking the engine out to fix a few things and while there I was thinking to reseat the oil pans and trimming cover .
1-do the heads have to come off to get to the bolts in red ?
2-the seals needed are # 130? is 110 rear crank seal? what is 100 and 105?
3-from the timing cover diagram are these the only part number needed 10 -25-70 ? is # 25 the only front crank seal?
I know I also need the oil filter housing , thermostat, water pump gaskets
thanks guys
Old Mar 14, 2022 | 10:55 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by ertech
Hi guys
thanks guys
Either post your VIN, or PM to me and I will look up the parts.
Regards,
Joe
Old Mar 14, 2022 | 01:43 PM
swedepat's Avatar
2011 C63 AMG, 589hp
100 and 105 is required o-rings, they sandwitches between the girdle and engineblock, they seal up oil pressure from pump.
The ones sitting there is often hard and brittle.
Yes it is possible to remove front cover without pulling the heads.
Yes, the three bolts located(6 bolts in total) is required to undo.
And remember unbolt and take out the hydraulic tensioner for the chain, located on right side behind alternator.
