C63 AMG (W204) 2008 - 2015
PCV replacement question
Old Aug 19, 2023 | 01:51 PM
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
Has anyone actually changed their own PCV using this link/method
https://mbworld.org/how-tos/a/merced...v-valve-388994
I've tried for days and can't get to the back side of this thing. There is no room and I really don't want to pull the manifold until you guys say it's impossible
Old Aug 20, 2023 | 09:57 AM
fflmlf's Avatar
2013 C63
Removing the intake isn't that bad at all, just buy the new gaskets and bolts before you do the work. It's more work, but well worth the time saved and lack of blood loss. Good time to do injectors while you're in there.
Old Aug 20, 2023 | 11:38 AM
95gsrturbo's Avatar
Injectors on 60k miles ?
My friend who works as a mechanic at MB dealership for over 20 years is talking me out of injectors even though you... As well as others have recommended it
Old Aug 21, 2023 | 09:36 AM
GarlicBread's Avatar
AMG C63
Stock injectors can fail and hydrolock the motors.
You can search this forum and find more than few threads where people have had injectors fail before 60k.
I replaced mine at 75k.
Your car, but if i remember correctly injectors were like 400-500 bucks for bosch oem replacements so not really that expensive.
Old Aug 21, 2023 | 10:12 AM
fflmlf's Avatar
2013 C63
https://www.fcpeuro.com/products/mer...sch-1560780023
Cheap insurance.
Old Aug 21, 2023 | 02:52 PM
6_Myles's Avatar
1998 E300TD
It's very difficult to do it that way on my E class....I can't imagine how exponentially worse it is on C class.
Old Aug 21, 2023 | 06:11 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Do the injectors for sure
Old Aug 21, 2023 | 08:21 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I agree do the injectors, not worth hydro locking a motor as they are know to fail and they are typically pretty crusty even by 40k miles.
It is basically impossible to do the PCV without taking the intake off and if you some how manage it, it takes 5 times longer, super easy to remove the intake and the intake gaskets are prone to leaking anyway so worth doing and if your PCV needs replaced you might as well clean the intake manifold as it will be full of oil anyway so you can do what when it is off also.
Old Sep 2, 2023 | 05:57 PM
tphss's Avatar
W204 C63 P30 / C190 GT S
At what mileage should injectors be replaced the first time for peace of mind? 40k miles?
Old Sep 3, 2023 | 09:08 AM
95gsrturbo's Avatar
I've been reading 50-60k miles
My car has 57k
Old Sep 3, 2023 | 11:55 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Mileage at a certain point is irrelevant. Several factors such as what fuel is used, how you drive your car, do you have a catch can and how long have you had it.
I did mine at 125k km ish and they looked excellent.
