Problems with timing after camshaft adjuster repair
I am currently working on my C63 to change the camshaft adjusters on all 4 camshafts.
Before that the engine was running fine except the start-up rattle.
Now I got following problem, I can't seem to get the timing right:
I turned the engine to 40degree after OT, the timing plate on the rear would only fit on the right bank not the left.
So I decided to redo the timing on both banks to properly fit 40 degrees after OT.
After the first time building in the camshaft adjusters on the right bank the timing tool wouldn't fit on 40 after OT anymore, it only fits slightly before 40 after OT.
Therefore I redid it (changed bolts again), removed the camshaft adjusters and turned the camshafts carefully with a wrench so I can fit the timing tool in the back and the front (the one that goes on top).
Reassembled the adjusters.
Then I moved on to the next bank, did the same thing (moving camshaft so rear tool would fit) and assembled the camshaft adjuster by using all timing tools.
Now when I turn the engine 2 times, the timing on both banks is off again. Right bank is slightly before 40 after OT, left bank is (even more) after 40 degrees after OT.
I only used 1 set of timing tools the whole time.
What did I possibly do wrong?
The rear timing tool (plate) was always hard to remove after building in the camshaft adjusters.
Thanks for your reply.
I am not far from surrendering and taking the car to a shop to get the timing fixed.
Sorry I know its a pain....we have all been there. Once you do it a few times you can apply to be a master engine builder at AMG
You can time one side and if the other is out of sync (as in, you can't fit the bar on the back) you can do that one after. The first side isn't going to drift. If it does from manually rotating the engine, you're going to have major problems once you fire it up.
If you time one bank and the other is out of time. Odds are you just need to put a wrench on each cam to advance them slightly so the bar fits on the back.
You only need 2 tools if you plan on taking all 4 adjusters off at the same time.
thanks for the reply. I got a second timing tool and got the timing right now (after several times fastening and turning engine.
Now I have another weird problem.
Ive used the titanium camshaft bolts from 63 motorsport: https://www.63motorsports.com/afterm...camshaft-bolts
After loosening the screw, I got problems with a squeaking noise upon retightening (starting at around 40NM) and its getting really hard to keep rotating.
Ive checked the thread, cleaned it and chased it. Thread of titanium bolt also looks good.
The Old OEM bolts (TTY) still go in well without issues.
Here is a video:
Do I have to use an Anti-Seize when tightening these down?
On 63 Motorsports homepage there is no instruction to do so.
Here is a video: https://youtube.com/shorts/xMt7os50XcY?feature=share
The giant phaser bolt is one time use and is torqued in at 40 ncm then a 90 degree turn to keep that sucker in by stretching it. + 5-10 ncm by mistake will not affect it. Tasos went to town on those phaser bolts and it took a ton of torque to snap it.
I would only possibly....posibly suggest thread lock on cam bridge bolts as there make their way loose...
I went back to use the OEM tty bolts and managed to put everything together and get the timing right on both banks.
After putting everything back together the engine was running fine. No more startup rattle.
I did a testdrive, did the relearn procedure and was very happy.
However....
After changing the oil and adding Liqui Moly Ceratec, the car has a start-up rattle again.
It only lasts for a second or less and must have to do with oil pressure, as starting the engine twice in a row the rattle is not existend.
Once the car sits for ~30Minutes the rattle comes back during start-up.
I checked with a diagnostic tool, no faults. Car runs great and very calm besides the start-up rattle that came back.
Any idea what this could be?
Is there a chance the timing chain tensioner has an issue and loses oil pressure, which leads to this rattling?
Leo
I noticed this movement in the center stick of the oil filter housing.
Is this normal or could it lead to oil flowing out of the filter?
