C63 AMG (W204) 2008 - 2015
Slightly overfilled oil
Old Oct 11, 2025 | 10:55 PM
Mr Jones's Avatar
2013 C63 PP
I topped up my oil but it looks like I’ve put too much in. Is this a problem? Should I drain some of it? Will it cause any damage with this amount?
Old Oct 11, 2025 | 11:43 PM
W205C43PFL's Avatar
Drain some, at what time did you do this measure?
Old Oct 12, 2025 | 12:37 AM
Mr Jones's Avatar
2013 C63 PP
Photo was taken the day after topping up the oil. 5 mins after drviing i.e. the car was warm.
Old Oct 12, 2025 | 01:37 AM
Mort's Avatar
I would recommend draining some oil as well. It is not good to have the crankshaft dipping into the oil and frothing it up. If it is doing that it is not good for the engine or the oil. The engine does not need to be warm. Try to drain out about a quart/liter and see where that leaves the level. Easy enough to add some back if you think the level is too low.
Old Oct 12, 2025 | 02:05 AM
amgfreak87's Avatar
Don’t drive the car like this. I would say it it more than a liter overfilled.
This often happen when you fill the factory spec amount (8,5l) without draining the oil cooler. If you only drain the oil pan, only 7,5 l are needed.
- Engine sitting level at operating temperature
- turn engine off
- wait five minutes
- Wipe dipstick clean and insert it slowly!!! while slightl wiggling the dipstickhead to avoid misreadings due to compressed air in the dipstick tube.
- take reading
Old Oct 12, 2025 | 05:01 AM
W205C43PFL's Avatar
I see then agree with other forum members, have some drained.
Old Oct 12, 2025 | 08:42 AM
Mikes62's Avatar
Get a Vevor fluid extractor or something similiar. It will make removing that 1/2 quart very easy. For $40 it will be nice to have for the future oil changes.
Old Oct 12, 2025 | 09:30 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Yes take some out, these cars are picky on oil level and over filling is not good for them.
