C63 AMG (W204) 2008 - 2015
Check Engine light
Old Mar 18, 2026 | 09:28 PM
Foosi's Avatar
W204 2013 C63 Amg
Check Engine light
Running into some issues with my 2013 C63 139k miles. P0175 (System to rich Bank 2) P2190 (System to rich at Idel bank 2) As well as rough idel. Both of these codes have come on randomly. For Ex: driving today for about 45min car is running great and then randomly at a traffic light noticed the check engine light turned on. drove it in C the rest of the way home still running fine just didn’t want to push the cars limits. I cleared the codes but it still seemed to be having some type of rough idel. Not really sure but you can hear it in the video.
MAF sensors are clean, injectors were just replaced 6k miles ago. checking O2sensor, Exhaust for any leaks and PCV valve Tomorrow. Last resort is take the intake off to check for leaks. but that’s all I can think of. Let me know if anyone has had similar issues and were able to fix them.
File Type: mov
Old Mar 19, 2026 | 07:29 AM
Joshinator99's Avatar
ML 63 AMG
Originally Posted by Foosi;[url=tel:9273431
9273431[/url]]Running into some issues with my 2013 C63 139k miles. P0175 (System to rich Bank 2) P2190 (System to rich at Idel bank 2) As well as rough idel. Both of these codes have come on randomly. For Ex: driving today for about 45min car is running great and then randomly at a traffic light noticed the check engine light turned on. drove it in C the rest of the way home still running fine just didn’t want to push the cars limits. I cleared the codes but it still seemed to be having some type of rough idel. Not really sure but you can hear it in the video.
I would be looking for intake tract leaks of some kind. Just my 2 cents.
Old Mar 19, 2026 | 09:16 AM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
while in idle, spray some brake cleaner around the intake manifold. If the idling changes you have a leak.
Old Mar 19, 2026 | 01:17 PM
yfz rock's Avatar
2011 raptor 2010 C63 AMG P31
i had the same issues i replaced the PCV and took the intake manifold off did an inspection/clean reassembled it and put in new manifold gaskets bolts no more issues.
Old Mar 21, 2026 | 09:24 AM
Norge507-4's Avatar
2018 Panamera ST turbo, 507 4 door
If PCV, can’t you unscrew oil cap at idle and if suction it is ok, no suction or blowing out then PCV not working.
Am I correct here?
Old Mar 21, 2026 | 10:41 AM
yfz rock's Avatar
if you haven't replaced it before just doing and inspect manifold plus its not super expensive and a peace of mind.
Old Mar 22, 2026 | 10:00 AM
Detailer's Avatar
2014 C63 507 Sedan - 2009 P30 SLK 55 AMG
Smoke test it first and check for leaks, anything else is guessing.
Old Mar 23, 2026 | 05:29 PM
Foosi's Avatar
W204 2013 C63 Amg
Am I correct here?
I have heard this trick but i’m pretty sure it’s with the Dip stick not the oil cap, not sure if it’s a real thing or not. Currently out of town this is probably the first thing I’m going to do. And then take intake out.
Old Mar 23, 2026 | 05:30 PM
Foosi's Avatar
W204 2013 C63 Amg
I am assuming if I take it out I have to purchase new bolts and new gaskets?
