C63, C43 AMG (W206) 2023 -
Help! Engine noise.
Old Mar 19, 2023 | 12:37 PM
Jmar9289's Avatar
2010 c63 AMG
Help! Engine noise.
New here in hopes to get some help. So quick run down my car is a 2010 c63 Amg engine mods are as follows
replaced head bolts 2017
weistec stage 2 supercharger
weistec tuned
weistec long tubes/full exhaust
built trans
weistec torque converter
some other odds and ends but that’s for the major stuff
now my problem is the top end is making some LOUD! ticking noise it sometimes is at cold start sometimes at hot sometimes all the time sometimes not at all.
I’ve pulled the valve covers and checked the cams for wear. I didn’t see any wear and the lifter buckets all seems fine no crazy wear that I could see. I also checked the cam adjusters the intakes had very little movement exhaust were solid.
I’ve changed oil twice currently using 0w-40 Mobil one I’ve used this many times before with no problems I’ve also added some friction additive still nothing .. here are some videos for reference. One video no noise. Other with. Any input would be appreciated.
File Type: mov
File Type: mov
File Type: mov
