OBD2 Gauge Solution for Bi-Turbo Cars incl W205 C63
Following is the list of parameters that the gauge supports
IAT
Ambient air
coolant
cat temp b1 & b2
rpm
boost
MAP
MAF lb/min
MPH
Throttle %
Ign Advance
STFT
LTFT
engine load
fuel status (open /closed loop)
fuel rail pressure
fuel rail pressure (direct injection)
MPG
HP
run time
barometric pressure
battery voltage
oil temp
Lambda
commanded EQ ratio
AFR commanded
TCC slip
TCC state
current trans gear
trans temp
torque to trans
analog 1 input
analog 2 input
The gauge has a performance timer (0-60, 1.8th, 1/4 mile), read and clear DTC's, record, cyclic scan.
Picture of the gauge mounted on a CLS63
