C63/C63S AMG
Drove the Eurocharged tuned C63S, Holy Hell!!
Old Jun 27, 2015 | 03:54 PM
zibby43's Avatar
'20 GLC300 SUV
Originally Posted by Will617
Thanks for sharing Zibby
My pleasure, Will!
In case you or anyone else is interested, here is a list containing all of the Top Tier retailers in North America:
http://www.toptiergas.com/retailers.html
Old Jun 27, 2015 | 04:47 PM
mister2d's Avatar
15 AMG C63S ED1
Originally Posted by zibby43
My pleasure, Will!
Costco baby
Old Jun 27, 2015 | 05:38 PM
ML63 AMG's Avatar
CL63 AMG
Yes and those horsepower numbers are absolutely accurate from the seat of the pants. To be conservative I would say 620hp/tq at the cranks. These drive trains are getting much more efficient these days.
Tune is on pump 93 octane. The tune is not released yet, but it will be soon and will be worth every bit of the wait, so hold out just a little bit longer
Old Jun 27, 2015 | 05:43 PM
ML63 AMG's Avatar
CL63 AMG
Originally Posted by matt11212
Was everything stock other than the tune and pipes? You get to try launch control? I wonder how those skinny tires outback handle that power.
Everything was bone stock, no downpipes on the car yet, just tune made those numbers. Honestly the car sounds perfect with the optional valves exhaust, but if you want more top end power downpipes are a must. I wouldn't be surprised if downpipes added another 30-40hp on top end
Traction is a WHOLE different issue. Stock tires cannot handle the power. A super sticky wide set of pilot super sports all around will help, or even sticker like a Dunlap ZII or Potenza 71-R. Once it hooks though... MY GOD. It's really fun to shift it into higher gears in manual mode at low Roma and use that massive tidal wave of torque
First gear is literally non existent, it's honestly a joke lol
Old Jun 27, 2015 | 07:54 PM
irablumberg's Avatar
2015 C63S E1; 2016 C450 AMG
I hope this tune can be installed through the OBD II port. I'm really not interested in digging out my engine control unit and shipping it off.
Old Jun 28, 2015 | 12:35 AM
AHI's Avatar
AHI
AMG GTR
I 💙 Eurocharged
Old Jun 28, 2015 | 01:26 PM
  #32
ML63 AMG's Avatar
CL63 AMG
Right now it is not OBD2 port tunable. And the ECU is in a very difficult spot to get to. The is a double edge sword as it costs a bit more to do the upgrade... However, NO dealership will waste their time to try and locate it and see if there is a tune on it. So it's actually much safer to do this tune than previous generations with regards to warranty be its simply not worth their time.
Old Jun 28, 2015 | 01:31 PM
  #33
Will617's Avatar
2016 C63S
Yeah but won't they find out when they (MB) when they hook it up if there is an issue which is warranty related?
Old Jun 28, 2015 | 04:02 PM
  #34
ML63 AMG's Avatar
CL63 AMG
That cannot be ascertained by a simple OD port diagnostic. They would literally have to take the ECU ou, which on the w205s is a massive pain. As long as you don't have a bunch of externally visible modifications of any kind, they will assume the car is stock.
Old Jun 28, 2015 | 04:43 PM
  #35
FastLaneJB's Avatar
335d xDrive, C63S on order
I don't think that can be said for sure. There could well be a tell in the data it presents which lets them know something is different. I'm no car person so don't really know what data it does or doesn't tell them but would it not tell them boost pressure? So if they floor it they can see the boost is going higher than would be possible on stock.
I get though they might not look for it but I imagine MB will come up with a way to tell if a car has a tune without the ECU being removed.
Old Jul 1, 2015 | 12:11 PM
  #36
ML63 AMG's Avatar
CL63 AMG
No there is no tell in the Data, even Jerry said it's impossible unless they take out the ECU and put it on a bench tuner. Boost levels are barely increased for the tune so it's nothing that would pop up out of the ordinary.
Old Jul 1, 2015 | 12:22 PM
  #37
msd3075's Avatar
'15 C63S
If your engine/driveline is blown and you're attempting to replace it under warranty, I'm sure the MB tech will go to the trouble to check the ECU.
Old Jul 1, 2015 | 01:29 PM
  #38
FastLaneJB's Avatar
Interesting that the boost is barely increased. How are they getting another 150hp odd from the engine? I'd assumed it would all be from more turbo pressure pretty much.
Exactly, I agree they probably won't notice, care when it comes to a service or such. However if it comes to the point that you need some major engine work then they've already got to do a lot to the engine so the fact the ECU is hard to get at probably won't make a difference then, they'll be likely to check it.
Having said all of this I'd certainly consider this after having the car for a while so if there is anything going to happen with the engine it's much less likely by that point. I'd not do something until you've clocked up a good few miles as problems are more likely to crop up early on and then the risk tails off. At least until you get to huge mileage numbers.
Old Jul 1, 2015 | 03:16 PM
  #39
betrezra's Avatar
C63 507 AMG DA Car #19
Fast - HP/TQ increases can be had over base tune through the following:
1. Increase boost.... not just peak boost... but boost map, in all gears.
2. Increase timing...... getting LESS conservative..... and perhaps doing this with the requirement to run 93 octane fuel.
3. Optimize AFR..... getting LESS conservative..... and perhaps doing this with the requirement to run 93 octane fuel.
4. Trans optimization...... not more power..... but optimized shifts.... not sure if they are playing with this yet.
When I visited with the AMG rep at my local dealer, he said there was another 3-5 psi on the table based on what the CLA45 guys were doing with half the engine, but similar c/r stock boost levels.
Old Jul 1, 2015 | 03:34 PM
  #40
Additionally, it is almost certainly the case that AMG has installed torque limiting in the engine program for the lower gears. Removing or at least diminishing that can also make a very significant difference in performance without ever pushing the engine or transmission beyond their respective stock limits. Of course you may need tires with better traction to take full advantage of such a change but that is a small price to pay ;-)
Old Jul 1, 2015 | 03:59 PM
  #41
betrezra's Avatar
Ira - yep. Please let us have the hp/tq of the engine in all gears
Old Jul 1, 2015 | 05:53 PM
  #42
FastLaneJB's Avatar
So in the UK with our manual the car already needs 98 RON fuel where as normal is 95 RON. Even some of the super unleaded like BP's is only 97 RON. So it already really should only be run on 93 octane fuel as its branded in the U.S.
According to the manual it'll run with 95 RON but you shouldn't try to use all of the power. So to me it's already setup to use premium fuel at least here.
I get Merc will still have left a good deal of room to play but 150+hp worth? There isn't better fuel I can get at the pump here really.
I believe by the way from some reviews the first 3 gears are torque limited because even with the limit it can still brake traction easily. I imagine with those limits removed and no traction control on your be spinning up to silly speeds. All the way straight to a tire shop
Old Jul 1, 2015 | 07:23 PM
  #43
betrezra's Avatar
Good points FLJB - drag racers have been running "stock" motors closer to the edge in so called stock classes to eake out another 10hp or another tenth....... just wait until the serious quarter mile guys get ahold of this platform and add all the bolt-ons the traction tricks, and all the I/C wgt reduction tricks..... it will get interesting.
There are stock suspension fox body mustangs running 10's with small slicks...... and the c has much better suspension than the tired fox, and much better diff.
Old Jul 4, 2015 | 08:45 AM
  #44
TheOtherDodge's Avatar
2005 E55 AMG
As a software manager and "ex-programmer", I find it hard to believe that it would NOT be easy to see if the ECU has been flashed. But it is like the old saying "the bad guys are always trying to stay 1 step a head of the good guys"! :-)
betrexra, the old tired fox is also about 500 lbs less than this C class.
Old Jul 5, 2015 | 10:36 PM
  #45
AV1's Avatar
AV1
C204 C250-CDI
Out of curiosity you don't have the higher octane ethanol blends there in the U.K ?
Here in Australia we now have 100 & 105 octane fuels available at the pump, I know of some A/CLA45 owners running tunes and very high power/torque outputs with this fuel, obviously not good for older car/engine types but AFAIK ok to use with all newer vehicles.
Also torque limiting is something that's incorporated in most high power FI cars these days and has been for some time both with auto and manual transmissions, I have an 11 year old Opel with a 2ltr turbo manual and it's torque limited in 1st and 2nd, also cars like the Mazda MPS are torque limited in the initial gears, the list goes on and on.
Most software tunes can totally remove or at least partially remove the limiters.
Old Jul 5, 2015 | 11:28 PM
  #46
FastLaneJB's Avatar
Strangely we cannot get 98 RON but we have the following:
95 RON = Normal and everywhere
97 RON = BP Ultimate
99 RON = Shell vPower and Tesco Monument
So I'll be using 99 RON when I get mine. We did have 102 RON for a short while but only 20 odd stations in the country sold it and they stopped a good few years ago. Guess there wasn't enough demand for it.
Old Jul 6, 2015 | 04:13 AM
  #47
AV1's Avatar
AV1
C204 C250-CDI
Interesting thanks for the info
AFAIK the RON is measured differently from Country to Country.
Here it's:
92 RON = Normal everywhere
95 RON = Premium unleaded everywhere
98 RON = Shell VPower/Optimax, BP Ultimate and pretty much all the other main suppliers also have 98 RON.
100 RON Shell VPower/Optimax was only available at limited stations and stopped after a short duration, supposedly not many people using it here either as you mentioned above.
100 & 105 RON = United ethanol blends, only recently the 105 - we'll see how long that lasts, hopefully the 105 stays long term.
I've tried the United 100 in my other FI vehicles with tunes and it makes a definite difference compared to the other 98's, yet to try the 105
Old Jul 6, 2015 | 05:15 AM
  #48
ML63 AMG's Avatar
CL63 AMG
You will NOT be able to blow the motor... Trust me. The only thing is you may over cook the turbos (that's the only real weakness in the stock platform.)
Had a private confirmation with Jerry, when he told me the real natural limits of the engine... My jaw literally hit the floor. AMG built this engine to be virtually indestructible. The stock 21psi is nothing compared to what the motor can actually handle.
I will put it this way... The M177/178 is the modern reincarnation of the Toyota Supra 2JZ twin turbo engine. You are NO WHERE NEAR the natural limits of this fully forged engine with this performance tune. I am sworn to secrecy to say one more
Moral of the story, go out an get the eurocharged tune, you will get the free upgraded reflashes for the life of the vehicle
Old Jul 6, 2015 | 06:46 AM
  #49
FastLaneJB's Avatar
That makes sense. Chris Harris mentioned in his review of the C63S that the engine is built to take almost diesel like pressures which is unheard of in a petrol engine. So fully understand the engine is extremely strong.
I suspect this is all because they'll use this engine across the board in the future and in cars with more bhp than the C63S. Not putting better turbos for this model is simply because they don't need to for the power outputs they are selling it at but the engine is the same to cut R&D costs I imagine.
I take it this tune won't over cook the turbos or that's a possibility?
Old Jul 6, 2015 | 09:08 AM
  #50
msd3075's Avatar
'15 C63S
What about other driveline components (transmission, diff, halfshafts, etc.)? Are those just as over-engineered?
You're only as strong as the weakest link in the chain.
