How to deal with breaking it in...
I have been sooooo good...and its not easy to be good.
Have had it set in comfort mode...and not revved over 4.5K...
How did all of you deal with your breaking in the car?
Just curious ----> also one question - comfort mode seems very slow on engagement of gears. I assume the other modes when I get to try them (after the breaking period is complete) is more quick to engage gears?
Also does the sound change in the other modes? I don't have the performance exhaust...
Thanks all....only have 500 miles currently. Maybe a few more longer trips are in order.
I took a 600 mile drive in it. Had to hit a grand as soon as I could and it was driving me nuts doing about 20 miles a day. Finally said screw it and took off for the trip. Got back and promptly tested the launch mode.
I've been driving in comfort exclusively for my morning and after-work commutes. I drive in sport any other time. I've accidently hit 5000 rpm while showing off the car to some people, so I hope nothing bad happens. I'm currently at 360 miles. Only 640 painful more to go.
2016 E63 AMG S SEDAN, 2010 E550 SEDAN
you mean revved over 4500 RPM
MotoMan break-in technique?
So, no one here is doing the MotoMan break-in technique? In short, you know, drive it like you stole it from day one. Red line it a few times to seat the rings right out of the gate, then change the oil immediately at 1200 miles and again at 5k....
I did this with my 2 x Audi S4's which were notorious for oil burn from the factory using their break-in techniques, and never had an issue with oil burn or the carbon build up others had... Those that used this technique also had no problems out to some very extended mileage.
Just wanted input....
X2
This is the best break in for any car. You get the temps up to operating levels. Then you drive the car like you stole it and make sure you do some downshifting/engine braking to seat the pistons correctly. I did it on my B8 s4 and never ever burned a single drop of oil. We are currently breaking in the wife's A3 in the same manner.
X2
I drove it like it would drive it any other day, after letting everything reach operating temps.
I've done this with every car I've ever owned, including the S4 that I just traded in with zero problems and 75000+ miles on the odometer.
When I raced Mustangs, one of my custom built racing engines had a hand written note of "Put belt on supercharger - haul ***" on the build sheet.
A45, Amarok, C63s Edition 1 wagon.
I drove my Mark V GTI like that before I sold it and it didn't burn much oil at all - and those things were notorious for it. My R36 has been treated in the same manner and it barely touches the oil - same with the A45. None of the cars have had any engine related trouble.
Isn't the car driven hard by the factory once it comes off of the assembly line for low mileage testing? That's what they do to a lot of sports cars,corvettes ,Nissan gtr,Porsche,Ferrari's,Lamborghini,dodge srt8s
Having said that this is a LEASE so who cares? I will baby it as much as I can over the next 800 but if you think I will keep it under 4500 rpm with paddle shifters and carbon ceramic braking you are nuts. I bet I burn through a set a tires in 2,000 miles.
This car was bought for fun and to share with my clients, oh and track days. It's a lease so to me its a rental car until I buy a GT-S next year.
I drove mine like I stole it for the 1st 50 or so miles to bed in the rings and then fairly carefully until 1000 miles. As I hit 1000 miles I raced an M4 for around 20 miles on a motorway. I asked MB to change the engine oil when having the diff oil changed at 1850 miles. They spoke to the amg guys and said it wasn't necessary. After a brief argument they changed the engine and diff oils at no cost. Now just over 4000 miles and most done at the red line including a trip across Europe and a few hot(ish) laps of the ring. At 5000 I'm gonna start modifying. I've always run in my cars like this and had very few problems with reliability.
First hand from AMG rep in a AMG event: break in is not necessary for the engine. He felt that the statements in the manual come from non technical people, translation legal.
I still do it as it isn't only the engine you are breaking in.
So I've been babying it for a long while now. When I pulled into the garage last night, I noticed this... So I'm thinking I should put more miles and beat the crap out of the car now?
So breaking it in can be a huge misunderstanding, and be argued for days. The fact is this. AMG breaks in the motor before it even gets seated in the engine bay, and the only thing your actually trying to break in would be the transfer case, and other suspension parts. The reason it calls for a transfer case oil change at 1000 miles is due to micro metal shaving left from the build. They want you to drive it easy and work these out in the beginning. Here are facts about how hard, fast you should break in a motor if you want your engine and tranny to be snappy and work together good.
A true engine break in is referring to the piston rings. All rings come a little out of round and not 100% flat, and the top of a fresh cylinder wall is somewhat rough. The rough walls main purpose is to act as a file and shave down the rings to be a custom fit in each unique cylinder there placed in. Now seating the rings can be the main catalyst that will make or break compression, which means power. Breaking in an engine slow and easy is not a bad thing but, doesn't give things the tightest seal. All race engines, motorcycle engines, and professional high HP motors get completely and undderly beat to heck from fist start, there trying to not delicately shave the rings into place, but slam them in for a tight seal. Realistically the engine either does or doesn't do this within the first 20 miles, depending on how you drive it. It's a known fact that motors broken in very hard the first 20 miles show increases of HP on the Dyno. So in short I have always been hard on my sports cars and never had issues from it.
Where does it say that it needs a transmission oil change?
It doesn't say it needs a transmission oil change. If you have the factory LSD it requires an oil change at 1875 miles. It may be different on the W205 because they are offering different LSDs on it depending on the options you get and they have an electronic LSD option now.
