C63/C63S AMG
c63 stock wheel weight?
Old Aug 30, 2016 | 09:11 PM
e920610's Avatar
w205c63s
hello,
what is the exact weight for this rims?
Im thinking to get HRE Flowform 01, does anyone know how much the 19inch ff01 weighs for?
Old Aug 31, 2016 | 01:28 PM
thewb's Avatar
SPONSOR
www.wheelsboutique.com
19" HRE FF01's in C63 fitments weigh 25.4 and 25.6 lbs respectively.
Old Aug 31, 2016 | 01:34 PM
e920610's Avatar
w205c63s
Thank you!
does anyone know the weight on the stock one?
Old Sep 1, 2016 | 11:31 PM
Edition1JPA's Avatar
C63 W205 Edition 1
Rear wheel weighs in at 23lbs...
Old Sep 1, 2016 | 11:35 PM
e920610's Avatar
w205c63s
So I guess buying these wheels would be a downgrade? Adding more unsprung weight...
Old Sep 2, 2016 | 12:46 AM
Sanch's Avatar
AMG GLC63 E-Performance Edition 1
Thanks man, that is good to know.
Old Sep 2, 2016 | 10:05 AM
thewb's Avatar
SPONSOR
Not necessarily. First well should confirm that the OEM weight mentioned above is accurate. Then you also take into account a wheel's durability, styling, and freedom of customization. Just for the sake of conversation - you can purchase a 19" wheel off ebay that is manufactured in China and weights 16 lbs but will it last over the first pothole you hit?
Old Sep 2, 2016 | 10:14 AM
PunjabiM3's Avatar
R8 5.2 6MT
I would say that is correct for the most part. The only advantage of going with the flow form wheels in this case is if the styling appeals to you much more than the stock wheels. Otherwise the stock wheels are better in terms of being lighter in weight and also being forged wheels compared to the HRE flow form wheels being cast. I think if you are going to go HRE you need to step up and get a normal forged wheel.
Old Sep 2, 2016 | 10:39 AM
alexasa's Avatar
c
oh please. Don't spew horse****. OEM forged wheels are going to be a much better product than an aftermarket cast wheel with a flow formed barrel.
Get real.
Old Sep 2, 2016 | 11:27 AM
bgm130's Avatar
2016 C63S
Here was my data from when i swapped my wheels.
Stock (mb multi spoke with vredestien wintrax)
Front 48.3 lbs 245/35/19
Rear 49.4 lbs 255/35/19
VFF103 vorsteiner (midnight black w/stock Dunlop sportmax)
Front 44.4 lbs . 245/35/19
Rear 48.5 lbs 265/25/19
Old Sep 2, 2016 | 12:33 PM
alexasa's Avatar
c
Considering a 19x10.5 only weighs 22.4 lbs. This sounds accurate.
Source: (http://f80.bimmerpost.com/forums/sho....php?t=1092326)
Tire weight between the two applications probably differs too - so hard to say specifically.
Old Sep 2, 2016 | 04:57 PM
C63 W205 Edition 1
Not the best scale, but it matches up with the scale at the gym and all the other scales I've been on within .5lbs to weight myself...
See the pic.
I have measured my Mandrus Rotec with Nokian Hak 8's studded tires versus stock wheel with Michelin PSS and they weren't far off... and the winter tires have lots of studs!
