C63/C63S AMG
Stop / Start and A/C
Old Feb 8, 2017 | 02:32 AM
the_big_1's Avatar
C63
Hi Guys,
Had my car in the dealer as stop start never worked (I know a god send to most but being OCD, I want it all working)
Changed engine mount and when I picked it up, Green stop start and was working fine.
On way home, I noticed the A/C button was off. I turned it on, off went the stop start green, back to yellow.
Turned A/C off, on it went back to green.
Tried it a few times and always the same.
Wasn't until I was another 10 miles through town that the A/C button stopped affecting it. Is this normal?
Outside temp is 7 degrees C and car set at 20 degrees C. Heater was on and felt no need for A/C to switch on as climate control is set to AUTO.
Old Feb 8, 2017 | 02:50 AM
sean1.8t's Avatar
c-fo-fiddy
Stop/Start function being regulated by the A/C and heater is totally normal.
These functions need the motor to be running to work. Not all the time, but most of the time, they need it running.
Old Feb 8, 2017 | 02:52 AM
the_big_1's Avatar
C63
Hi ya,
A bit weird that some times it needs it the A/C switched off when the car is actually heating up? I drove a C Class none AMG, forget the model and it didn't act the same. It didn't care if A/C was on or off.
Old Feb 8, 2017 | 02:57 AM
sean1.8t's Avatar
c-fo-fiddy
It's situational. I'm not sure why this is so hard to understand for you.
The A/C compressor needs to be spinning for it to work. You can get away with a bit of residual cooling but on a hot day, it will need to be spinning 100% of the time to work.
Same with the heat. The car cannot produce heat unless the motor is up to temp.
Old Feb 8, 2017 | 03:01 AM
the_big_1's Avatar
C63
But that's the point. At this moment in time, A/C isn't running, the car is cold. The outside temp is 5 Degrees today, car inside is aiming for 21 Degrees so A/C not required. The heater is switched on, this isn't stopping the stop / start from working. When I switch on the A/C switch, which should do nothing as A/C isn't required, the stop start turns off. The car isn't misted up or anything like that. I have another none AMG C Class sat next to the C63s, same temps, same time of day, two cars following each other, C63S wont stop start will not work with A/C switched on, other C Class the A/C has no effect???
Old Feb 8, 2017 | 03:04 AM
sean1.8t's Avatar
c-fo-fiddy
Geez man, you need therapy for your "OCD".
Take it to the dealer if you are so concerned. How are we supposed to help with this?
Old Feb 8, 2017 | 03:12 AM
the_big_1's Avatar
C63
lol I am OCD, part of being an engineer lol. The question is if anyone elses does exact the same?
Old Feb 8, 2017 | 03:17 AM
sean1.8t's Avatar
c-fo-fiddy
I know a person with actual OCD. I highly doubt you have it.
You're just being a Nancy.
Old Feb 8, 2017 | 11:31 AM
Fordgt40's Avatar
C63 amg esate
I'm just the same, if it's on the car I want it to work whether or not I use it, my stop start is is like yours, works sometimes, been to dealers a few times to sort it, new battery installed and still has a mind of it's own, sometimes the green light is on when moving orange light when coming to a stop, it's completely useless.
Old Feb 18, 2017 | 11:08 AM
toreav's Avatar
AMG C63T S - delivery March 2017
The Auto Start/Stop function also need a certain voltage on the battery. Cant compare to other cars without checking that the batteries are in similar state.
Very situational, chill with your OCD and take a longer ( 1.5hrs ) drive.
Old Feb 18, 2017 | 12:25 PM
400ixl's Avatar
E250 AMG Sport Convertible
A/C will still be in use if the climate control is on as it will still be drying the air to take the moisture out of it. It doesn't just cool the air. So until it has conditioned the air inside the car it will need to run which disables the stop start.
Old Feb 19, 2017 | 04:16 AM
Harold1898's Avatar
2015 E400 Coupe
Feel sorry for you that this is a problem. Go to the dealer and they will sort it out.
All the best.
Old Feb 19, 2017 | 03:28 PM
RDOCA's Avatar
2016 C63S Sedan
Your biggest problem is you are driving in comfort mode--STOP that and everything will be all right.
S+ is the correct setting --C is for when your wife drives it.
