C63/C63S AMG
oil filters 2017 C63S
Old 04-30-2017, 11:23 PM
jmwigen's Avatar
'17 C63S
Have a new C63S on order. Talked to the service manager and he told me that there are 2 possible oil filters for the '17. Anyone know about this?
Tks, Michael.
Old 05-01-2017, 12:00 AM
srO_Michael_Orz's Avatar
C63s(lost)/E250/GTR(Sold)/GTS(Carbonerre)
No, only one oil filter! But I can tell there are two places to drain oil, you need drain oil from two different place, if you want to drain completely.(even the WIS doesn't tell this secret)
jmwigen (05-01-2017)
Old 05-01-2017, 12:45 AM
jmwigen's Avatar
'17 C63S
Oil filter
Thanks for that, but you stated that one must drain the oil from two places.
Do you mean the oil pan and the filter housing, or is there another spot, such as from the oil cooler?
Old 05-01-2017, 12:58 AM
One is on the oil pan which is plastic.
There is another one metal oil drain Screw near the Y130. (The screw on oil pan is plastic).
Old 05-01-2017, 01:02 AM
jmwigen's Avatar
'17 C63S
Interesting. How much oil comes from that orifice?
Old 05-01-2017, 01:05 AM
Both combine should be near 9L.
If you follow the WIS procedure only drain the plastic screw, you may have 0.7-1L left at front.
Old 05-01-2017, 01:07 AM
jmwigen's Avatar
'17 C63S
Cool. Thanks.
Old 05-15-2018, 10:10 PM
theclutch's Avatar
C8, FF, C63S, 911 C4S, GTI, E350, Boxster S, 355, Esprit S4, Vantage, S5, Z4, M3, Miata, A4, 325is
I would tend to agree. Most of the oil came from the plastic plug near the oil filter. It makes me think it was sooooo NOT worth it going through the trouble of undoing the 6mm plug which was a major ***** to do with a 6mm allen wrench since a ratchet will not fit.
Old 05-16-2018, 02:56 PM
C63SVERT's Avatar
2018 AMG GTC Roadster. 2013 SL65 2018 GLC63
Cool. Thanks.
every parts guy at Mercedes will tell you this lol they will say "whats the vin"
Old 06-12-2020, 12:10 AM
TL441822's Avatar
2016 c63s sedan
where do you get these information? I want to read more how to change out part for m177 on my c63s
Old 06-29-2020, 07:17 AM
JRHolt's Avatar
2024 GLE 63 S AMG SUV
Here is the EPC showing the Plastic Oil Drain Plug, Oil Pan Drain Plug and seal part numbers.
15 and 20 are the Oil Pan Drain plug and Seal.
70 is the Plastic Oil Drain Plug. (Main Oil Drain Plug shown in WIS)
File Type: pdf
FlightC63 (06-30-2020)
Quick Reply: oil filters 2017 C63S
