C63/C63S AMG
Wheel Caps Missing
Old May 13, 2017 | 12:35 AM
milan25's Avatar
C63 s Edition 1 Sedan
Wheel Caps Missing
My 19" Cross-Forged rims are missing the center caps. The normal 75mm caps don't fit and I can't seem to find the right size. Does anyone know what size the center caps are.
https://www.kunzmann.de/shop/en/tire...k-original.htm
I found this but I don't need the lug cap.
Old May 13, 2017 | 11:29 AM
Dthquazi's Avatar
2017 c63s
Mercteil has a bunch but it doesn't specify the size. I looked around and it seems that they should fit your wheel.
Old May 13, 2017 | 12:46 PM
milan25's Avatar
Thanks Ill look on there
Old May 13, 2017 | 04:56 PM
Hector G.'s Avatar
AMG C63 S
Where did you find a spare? Do you have a part #. I had to replace a tire and the center cap insert feels loose. Did you notice the same issue when removing a wheel?
Old May 13, 2017 | 04:58 PM
Hector G.'s Avatar
AMG C63 S
The insert are loose on all my wheels. Is that normal ? Just noticed it today
Old May 13, 2017 | 06:09 PM
milan25's Avatar
Yes mine were loose and I told the dealership and they wouldn't cover it because its too expensive.
Old May 13, 2017 | 06:12 PM
milan25's Avatar
http://www.mercteil.com/en/my-style/c-class
still not sure if the ones here will fit
Old May 13, 2017 | 06:20 PM
Hector G.'s Avatar
AMG C63 S
So if the dealer wouldnt cover or fix the issue, what did you end up buying ? I mean I've lost one so far and the dealer sold me the entire center hub $200, but now since I noticed all the hub inserts are loose , I'm worried I may lose one while hitting a bump on the road etc, I mean it literally takes no force to remove the insert from the center hub
Old May 13, 2017 | 06:22 PM
Hector G.'s Avatar
AMG C63 S
These are the type of wheel I have
Mine is the edition 1 model so it comes stock with these wheels
Old May 13, 2017 | 06:55 PM
tekfoc's Avatar
Veteran: Army
18 E63S
Just silicon it on
