show AMG menu on the main display
It could well be a dumb question... but, is it possible to show the AMG menu (G-Meter or engine temprature) on the main display instead of the small display in the instrument cluster? thanks
That data can be displayed (engine temp, trans temp, horsepower, torque, g-meter) on the COMAND screen.
Vehicle -> Dynamic Select -> Engine Data or Vehicle Data
AlexZTuned (05-29-2017)
W205 C63 Coupe (Coming Mar '17)
The G-meter isn't available as such, as in it doesn't show how many G's but it does show where the centre of gravity is as you drive. It also shows the brake and throttle position in a bar graph, I find this is really useful for track days/tuition. From DYNAMIC SELECT, go to Vehicle Data.
Sure it is, select "vehicle settings" using either the favourites button or the main menu, DYNAMIC SELECT, Engine Data for engine and transmission temps.
700HP Facelift converted PFL C63 S Coupe
Your 2017 C63 S should have this feature already as yours is a later prefacelift. If you go to your screen and press Dynamic Select do you see the Engine Data display?
2017 c63 s No engine data display.
Hey thanks for responding, so actually when i turn my car on it only shows AMG logo on the screen, no Comand system message. When i go to Dynamic Select all i get is the Individual configuration screen and i use the joystick to try and navigate but appears there are no other options available.
