C63/C63S AMG
Active sound module
Old 11-04-2018, 08:32 PM
  #551
Liked 0 Times in 0 Posts
Mercedes-AMG C63S
After reading this whole thread (all 22+ pages!) I bought and installed the active flap control module from ASR Components (asr-component.de) on my 2016 C63s.
My main reason for going with the ASR style unit was the "plug and play" installation as I did not want to cut any wires or do anything which could be traced whilst the vehicle is under warranty, and can be easily removed if needed.
The installation process was amazingly simply. I did it in under 2 mins and the hardest part was removing the carpet in the boot. It is dead easy to locate the appropriate plug in the boot, disconnect it and connect the ASR module in its place. The unit did not come with any installation instructions however, and the company website only has instructions in German, so anyone about to install it should read the install instructions posted in this thread. (Thanks to those that posted them - really appreciate it!).
I did ensure the vehicle was locked and asleep for 10mins with the key fobs at least 20m away, prior to working on the vehicle as others recommended.
The change in both the level of exhaust noise, and the tone of the exhaust note, is a big improvement at low revs. I did some "before and after" measurements with a basic decibel meter and found:
- Before Install, at idle:
- Comfort Mode, AMG Exhaust Button OFF - 79dB.
- S+ Mode, AMG Exhaust Button ON - 84dB
- After Install, at idle:
- Comfort Mode, AMG Exhaust Button OFF - 85dB.
- S+ Mode, AMG Exhaust Button ON - 89dB
The tone of the noise is much deeper and 'throatier' as well which is more appealing to me than just being louder. It also seems to have a bit more pops and crackles coming off high revs, but its hard to quantify this on the road.
Overall I'm loving it, and so do my kids! It was a really simple install, makes the car sound even more aggressive, yet I can turn it off and creep around quietly without waking up the neighbours if I want to.
BiTurboLuv is offline
Old 11-04-2018, 09:23 PM
  #552
Liked 29 Times in 21 Posts
BMW X5
The improvement in both the level of exhaust noise, and the tone of the exhaust note, is a big improvement at low revs. I did some "before and after" measurements with a basic decibel meter and found:
Hey mate thanks for posting your experience with the ASR to date.
Has your car gone in for a service and had the most recent software update for the engine applied to it?
I'm just tossing up whether to buy an ASR or not, seeing since getting that software update the car seems to pop a lot more coming of the throttle, although no increase in volume or that throatier sound you were mentioning. So might still be worth getting it.
RHRAUS is offline
Old 11-04-2018, 10:45 PM
  #553
Mercedes-AMG C63S
Hey RHRAUS. Yeah I have had the engine and trans software updates. Took a lot of convincing to get my dealer to do it but they eventually did.
The ASR and the software updates have slightly different effects. The software update definitely gives me more pops and backfires / crackles than before the update. I seem to get more in all modes, and they also occur at lower revs than before. The best is still S+ or Race modes coming quickly off wide throttle or downshifts at high revs.
The ASR module mostly allows a lot more noise through at low revs. As I mentioned above though, as the software update seems to give pops at lower revs now, with the ASR on these do come through better. So for example in S mode with ASR OFF you can hear the extra few pops from the software upgrade; but with the ASR turned ON they are much clearer and it sounds like 1 or 2 more pops as well. I doubt there are extra pops magically being generated, but with the exhaust flaps open the quieter pops can now be heard whereas before they were suppressed and probably weren't being heard. I'm no expert in these trick exhaust systems though so this is just what it sounds like to me anyway...
Old 11-05-2018, 12:19 AM
  #554
BMW X5
Thanks Biturboluv, sounds like it still might be a good addition in that case. Thanks for the feedback.
RHRAUS is offline
Old 11-13-2018, 04:43 AM
  #555
Liked 24 Times in 24 Posts
2016 C63 S Edition 1 Coupe, 2011 640D M Sports Coupe (now gone), 2015 435i M Sports Coupe
Originally Posted by JWreck View Post
Do you have any information on installation?
No but just plug and play very easy just unplug white connector under floor in boot plug in connector from unit done takes 2 min, there is at installation sheet with the unit.
michael640D is offline
Old 11-20-2018, 05:42 AM
  #556
C63
Hey all... excuse the ad - mods please shift if needed.
I'm in Brisbane Australia and have an ASR module with remote controllers that I no longer need, pulled from my C63S before sale. Perfect condition.
PM me if interested - AUD $300, happy to ship wherever.
My thoughts on it - fantastic... very worthwhile and super easy to install.
LM200 is offline
Old 12-30-2018, 03:26 PM
  #557
Liked 4 Times in 4 Posts
2018 c63
Originally Posted by NJ 1161 View Post
To be honest I wouldn’t of bothered with these by passes and just unplugged the valves but earlier on in this thread it stated it may throw a fault code.
at least these will keep it tidy. £58 in the uk, but think others available in us, again mentioned previously in this thread.
https://www.ebay.co.uk/itm/Mercedes-...72.m2749.l2649
So, finally got round to fitting these on my uk 2018 ( simulator plugs) One side plug was a little bugger to get out but fitted in the end. My car was locked but I did open the boot ( boot gesture feature) as had my key near by midway and I’m wondering if this took it out of sleep mode as car was down on power when re started.
Sounded quiter if anything! No change In Sound flicking between modes so valves disabled but wondering if power loss has muted it.
I’ve re plugged in originals but had a few beers so will need to test tomorrow.
Whats poeples views? Is it the soft limp mode that has meant no noise difference?
Will it be be back to normal tomorrow? Should I try re fitting them when car is fully asleep? ( boot opened when one was un plugged?). Would the boot opening with valve unplugged cause power loss?
Do do I give up as 2018?
NJ 1161 is offline
Old 12-30-2018, 04:42 PM
  #558
Liked 5 Times in 5 Posts
C63 amg esate
I can’t answer you ‘down on power’ problem and to be honest I wouldn’t bother at all with anything to do with the valves on the 2018 because on the PE the valves are fully open when activated with the button, they are on mine anyway, I only discovered this after I installed the ASR which made no difference.
Fordgt40 is offline
Old 12-31-2018, 07:24 AM
  #559
2018 c63
think you may be right. For some reason unplugging the car and fitting the resistors did reduce the power but not as far as limp mode. Good news is after re plugging originals all back to normal power.
Guess second decat delete may be may be the way forward!
NJ 1161 is offline
Old 12-31-2018, 03:48 PM
  #560
2018 c63
I’m still intrigued as to what the Simms would do if no limp mode. Can anyone confirm if my cars locked overnight and I install in this state ( with key well away) would this be sleep mode? May give the simulators one more go just out of interest on the ‘18!
NJ 1161 is offline
Old 01-31-2019, 06:53 PM
  #561
2015 C250
Is the update done by a MB dealer ?
Enrique Borunda is offline
Old 02-09-2019, 02:04 PM
  #562
Liked 41 Times in 33 Posts
2017 C63s Coupe, 2018 BMW X3 M40i, 2011 Toyota Tacoma TRD 4wd, 2016 Ford Focus se Hatchback
Selling mine for $200 + shipping
see here. https://mbworld.org/forums/market/735429
See63esS is offline
Old 02-09-2019, 02:15 PM
  #563
2015 C250
The link is not working, what is it ?
Old 02-09-2019, 02:41 PM
  #564
weird. Link works for me. It’s the ASR exhaust valve module with 2 remotes.
https://asr-component.de/home/51-kla...erung-rx1.html
See63esS is offline
Old 02-11-2019, 11:30 AM
  #565
2015 C250
I am told that the ASR module does not work on cars with no performance exhaust, I have the regular 2017 C63 without a PE.
Old 02-11-2019, 12:47 PM
  #566
C63 amg esate
It won’t work, only works on performance exhaust pre 2018
Fordgt40 is offline
Old 03-31-2019, 08:40 PM
  #567
DonC63's Avatar
Liked 2 Times in 2 Posts
C63
Originally Posted by AlexZTuned View Post
This is a pretty good video that shows how the OEM AMG Performance Exhaust is programmed to dynamically open and adjusts the flaps based on RPM/engine load. At idle with the exhaust on, the valve is only about 50% open. It only opens to 100% for a brief second when revving hard. It acts similar when you're driving and under load, so forcing the valves to be 100% open should make a big difference even in part throttle.
https://www.youtube.com/watch?v=sry-ap0F1iY
By the way, whatever exhaust work is done to that Blue C63S Estate in addition to the CETE module sounds absolutely amazing. I haven't heard a better sounding setup on the M177 than that, very very similar to the GTR's stock exhaust.
I just bought my car tuesday, and now I know why it sounds like a helicopter while sitting at stop lights, After reading this thread I am wondering if installing a simulator in the H pipe and keeping that valve permanently open would at least equalize the exhaust pulses and get rid of the helicopter sound. I don't want to have to use a separate remote control, or cut wires on my brand new car, so maybe my idea might be a way to at least make it sound smoother at idle??
DonC63 is offline
Old 04-01-2019, 10:19 AM
  #568
DonC63's Avatar
C63
I just talked to Eurocharged Performance, they told me if I bought a hand held tuner, they could make the exhaust flaps be either fully closed or fully opened, none of that half open crap. I don't know if it is true, so can anyone with a Eurocharged tuned car confirm that for me
DonC63 is offline
Old 04-04-2019, 05:52 PM
  #569
DonC63's Avatar
C63
They called me back today,and told me they can't control the exhaust valves. Oh well was worth a shot
DonC63 is offline
Old 04-04-2019, 08:48 PM
  #570
Liked 7 Times in 7 Posts
2016 C63S
lol. Oops.
ezatnova is offline
Old 04-04-2019, 11:53 PM
  #571
Liked 3 Times in 3 Posts
2017 C63S Sedan
You need someone who has access to control units settings(Engineering Software which is only available to Mercedes engineers in Germany), just a change of coding will do that for you, I have mine hard set to 100% open all the time. If you live in Greater Toronto Area, then I can get someone to help you with this. The entire process takes less than 5 minutes.
And it will be extremely loud inside your cabin if you had catless downpipes installed.
g2lujinn is offline
Old 04-05-2019, 08:15 AM
  #572
DonC63's Avatar
C63
I wish I was closer to you, and no I don't have any plans for catless down pipes, maybe higher flow catted down pipes down the road. Wish AMG would provide this change of coding to dealers. I assume it uses a MB diagnostic computer/software, and that someone with that equipment and knowledge could do what the person you know can do.
Can you tell us more about how this is done
I am in Massachusetts, but moving to Florida in May
DonC63 is offline
Old 04-05-2019, 08:25 AM
  #573
untamedd's Avatar
Liked 13 Times in 11 Posts
2017 C63S Coupe
which valve you referring to? Mufflers or the one in the middle? The car has 3 valves.
untamedd is offline
Old 04-06-2019, 09:16 AM
  #574
DonC63's Avatar
C63
would love to do all three but if some programming or coding can control any of them would be happy. Though the most important to me would be the valves in the mufflers
DonC63 is offline
Old 04-08-2019, 12:15 AM
  #575
2017 C63S Sedan
the one in H-Pipe and two in mufflers, so yes, all three valves
g2lujinn is offline
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
