Active sound module
#576
i did that with the centre H valve since it was making too much rattling noise. The H valve wont change the volume but instead the tone. Car sounds more throaty, startups and downshifts are meaner.
#577
Have an ASR module for sale, taken off my 2017 coupe since I've now got a 2019 and they're incompatible. Also have AWE valve sims for sale. Based in UK but willing to ship at buyer's cost!
If you have a 2017 or earlier, either of these are a no-brainer mod IMO!
#579
Well, I'm very late to the party and this is one very long thread. First off, I just bought a 2017 two days ago and keep reading about a software update that changes the exhaust sound. It sounds like they added more pops/burbles/overrun sounds based on what I'm reading but when I asked a local mechanic friend here in Canada he said the only update he knows of was to fix some of the misfire problems they were having and would actually make the car quieter. So much so that customers are unhappy after the update at the sound. What's the fully story on this?
Second, I see a few companies posted here but it appears like most people are happy with the ASR but the website is clearly not in english and a bit hard to navigate because of that. What is the direct link I should be ordering from? Or better yet, does anyone have a fully working one they want to sell?
And finally, I might have missed it but does anyone have a quick install video that they made themselves of the install as I'm sure instructions aren't in Canada. If you don't press the "closed" button on the remote will the flaps always stay open even after restarting the car and/or disconnection battery?
#580
Update mutes exhaust sound.
Use Google Translate for the ASR website.
https://asr-component.de/startseite/...1_mit_schieber
You can set flaps to do whatever mode you want on startup.
#581
I contacted them and it's going to end up being about 500 CAD shipped to me, plus whatever crazy "brokerage fee" UPS seems to add on. If I don't plan on ever closing the flaps with the remote, is there any negative to using the awe valve simulators? As I skimmed through the thread the other night I noticed a lot of people having a problem losing power ("soft limp mode"?) with them that followed the install steps properly, is that ONLY on cars 2018 and above? I have a 2017 and don't mind not being able to control the valves, plus I plan on going with an awe track exhaust down the road. Also, is there any point where they might put the car in limp mode AFTER they're installed (ie: software updates, battery dieing, etc).
#582
Hey guys. Just wanted to update this thread given I used it to make my purchase.
i have a 2018 c63s cabriolet. UK spec. Not sure of build date but it was delivered to the dealer around March 2018.
ASR module appears to work fine in mine.
i opted for the remote with numbers on rather than lock / unlock should that make any difference. And the module I received looks a little different to some of the ones posted on here (black casing). Possibly just updated aesthetics.
From what I can gather:
button 1 - exhaust fully open
button 2 - exhaust fully closed
button 3 - back to standard (exhaust button in centre console control)
#583
I need to email them them to see if any module will work on mine?
Are you happy with it? . Worth the money?
#584
Be good to know which module you have? I fitted simulator plugs to my July 18 and put it into limp mode. I’m thinking maybe March 18 could be 17 build hence no issue?
I'm happy with it, easy to fit and 100% reversible with no cutting of any wires (big no no for me). I like that I can leave it in the open position 100% of the time and not mess with the exhaust button every time I get in the car plus you don't get that annoying momentary valve open and close effect on cold start which always bothered me. And for those rare occasions when I might want to take back control again I can just pop it back in to standard mode via the remote.
I know there is the version that connects into can bus and uses the factory exhaust button for the same effect. That's a big appeal too, but what I didn't like is you can't completely disable it. You use the traction control button to turn it off but I think it reverts back the next time you cycle the engine.
As others have said, it's change is most noticeable at low revs and there's no mistaking the difference.
It is a bit expensive. I've found a lot of these specific application modules generally are. But popularity and competition will only drive the price down. If you can swallow the price, there's little to be disappointed with if you want to get the most noise out of your standard exhaust.
#585
Hmm, I’m sold. It’s the low down I’d like to be louder, just the normal rumble on normal driving. Do have some early starts so need the ability to go back to quiet if needed ( well quieter!). Will need to contact them to see if the new model works with 2018.
Yes, it’s expensive but when the time comes to move on I would imagine you’d get a decent amount back if you re sell.
Re vin and build date. I’ve used this before.
https://carinfo.kiev.ua/cars/vin/mercedes/vin_check
just re did mine to see if still works and does. Only bit is where it says delivery date not sure if this means build date as mine is a July 18 registration and states delivery date as jan 18 which sounds about right. Someone more knowledgable may chip in,but worth a view and free.
#586
Delivery date 27 03 2018
EU approval date 20180111
Can’t find build date but assume it must be very late 2017 or very early 2018.
#587
#588
After ordering mine, it arrived around 3 day later to Sydney where I live.
Install was easy. Just have to make sure you find the right cables and tap into the same colour wires.
Been driving with it for about a week now. My thoughts:
Definitely noticeable difference in comfort mode, even with all the windows closed. The exhaust now gurgles and throbs. No pops.
Noticeably in sports+ mode.
It's a pretty expensive unit, so it'll come down to each persons opinion whether its worth the price.
But for me I'm happy with it.
I will do downpipes when the warranty expires.
Realbenz (09-14-2019)
#589
As fas as the car itself... I’ve done 2k miles almost and it definitely seems like the car is popping and banging more but under hard driving in sport+ engine mode.
#590
#592
I got the ASR version a few days ago and I think it’s 100% worth it.
As we all know, although theres no pops and crackles, the car does start to produce some sound as you reach higher RPMs. But for the first couple thousand RPMs the car was practically silent.
I feel like these modules create a reasonable exhaust progression from standstill to higher RPMs. But my favorite change is the standstill rumble. That was something that was really missing and I’m glad its brought back.
Wanted to record a video but unfortunately the day after I installed it someone vandalized my car trying to break into the trunk. So its in the shop for an estimated 2 weeks.
#593
#595
I installed the Renntech exhaust module on my car today, it is a 2018 sedan. I could definitely tell the difference at low rpm under load. Might be worth a try for the other 2018's out there that said the ASR didn't change anything.
#596
if like me you want loud all the time you can just unplug the valves. I have done this and noticed a difference down low and the car has been back to Merc 2 times now and they have not said anything about the valves being disconnected.
#597
Without a valve simulator to trick the car into thinking they're still being actuated? CEL no?
#598
#599
Interesting. Are you sure you're not down on power? For everyone else that did this their car went into some kind of limp mode. Is yours a facelift?
#600
Very curious about this.
I also want it open 100% of the time so if just unplugging the valves does the trick I might just get rid of the ASR
