C63(s) Coupe Carbon Fiber Collection by Mode Carbon
Former Vendor of MBWorld
E90 M3, F80 M3, C63 507, F90 M5
C63(s) Coupe (Facelift) Carbon Fiber Collection by Mode Carbon
C63(s) Coupe (Facelift) Carbon Fibre Collection by Mode Carbon
Technology:
At Mode Carbon, our manufacturing process takes full advantage of a dry-layup vacuum infusion process. This allows for less resin to be used in between the carbon fibers, creating a dramatic weight advantage.
The vacuum infusion technology of our process also ensures a perfectly even distribution of the resin. The result is a pin-straight weave pattern, which generates a more consistent level of structural integrity to maximize the overall rigidity of our carbon fiber products.
100% Carbon Fiber:
All raw materials used in our manufacturing are hand-picked from Germany, France and Japan to ensure that our carbon fiber products exceed even the most strict industry standard of quality.
The carbon fiber is finished with UV protected clear coat to prevent discoloration from sun exposure. The glossy finish not only provides stunning aesthetics, but also serves to maximize the longevity of our products by increasing their durability to the elements.
The Result:
Our commitment to quality is high-grade carbon fiber that reduces weight, increases performance and improves aerodynamics. Whether your car is for the street or dedicated to track use, Mode Carbon products offer an ample blend of quality, refinement and style.
The Collection:
- Edition 1 Front Splitter
- Euro-Spec Front Trim Replacement
- Front Grille Replacement
- Mirror Housings
- Edition 1 Side Skirts
- Luftstrom Rear Diffuser
- Coupe Bootlid Spoiler
Edition 1 Front Splitter: the Mode Carbon Edition 1 Front Splitter. Incorporating styling cues from Affalterbach, our Edition 1 Front Splitter turns your C63(S) into an untamed DTM-inspired beast without sacrificing daily drivability. Our 3 piece design protrudes outward from the front bumper, as opposed to sitting underneath it, thus preserving your ground clearance and allowing for a better approach angle. Street presence is off the charts with this one, adding a sinister front personality to match the racket coming from the spooling twin turbos. The left lane is all yours, and they will move out of your way.
Euro-Spec Front Trim Replacement: this products is designed to replace the dull plastic factory trims with an upscale, glossy carbon fibre fascia that oozes sex appeal and sophistication.
The Euro-Spec Front Lip Kit includes three pieces, replacing both the lower carbon fibre lip trim and the upper canard trim of the front fascia. Not only does this add a dark, menacing tone to the nose of your W205 C63, but the pop of carbon fibre weave gleaming in the light will be sure to turn heads. These pieces feature all of the same factory mounting methods for flawless integration.
Alas, Mode Carbon has the solution to complete that upscale look and feel of the Edition 1 launch vehicles with carbon fibre all around. We have taken things a step further than the OEM launch kit by adding the upper canard pieces in the front. For those of you looking to take your vehicle a step up with our bespoke carbon fibre package, your solution has arrived!
Front Grille Replacement: Our Carbon Fiber Grille Replacement for your W205 C63s Coupe platform is a stunning remedy for the mundane factory trim, adding a much needed dash of carbon fibre detail to the nose without sacrificing factory fitment. Our Grille Replacement is the perfect way to black out your factory grille while complimenting the rest of your carbon fibre components. This complete replacement utilizes the factory mounting points for a seamless fit and finish that is guaranteed when you purchase any of our carbon fibre products. Our Carbon Fiber Grille Replacement will integrate with your Distronic/Lane Changing Sensor without causing any drawbacks.
Mirror Housings: another subtle touch to the side profile of your W205 C63(s) adding character whilst blending in with the Side-Skirt Replacements wonderfully. If you have completed your vehicle with our Edition 1 Front Splitter and Luftstrom Rear Diffuser these bits are a must in order to keep the carbon fiber aspect of the car consistent. Replacing all the gloss black/plastic trim with vibrant yet understated beauty, they say it's the little things and we most definitely have to agree.
Edition 1 Side Skirts: Our Edition 1 Side Skirts for the C63(S) Coupe are an aggressive complimentary carbon fiber modification that is the missing link that ties together all of the carbon fibre on the front fascia and the rear end of your vehicle. This subtle yet vibrant addition is a simple touch that will remind you just how special your AMG is every time you enter and exit the vehicle. The little things definitely add up here, completing your C63s in our range of carbon fiber solutions definitely adds that powerful conviction that AMG is so synonymous for. If your attention to detail is keen then be sure to add this item to your wish list!
Luftstrom Rear Diffuser: We are proud to announce our latest offering for the ‘16+ C63 AMG Coupe, our Mode Carbon Luftstrom Rear Diffuser. This new design features bolder fins than the OEM component, for a more aggressive styling that does the quad AMG exhaust tips justice. We were careful to make sure that the styling does not go over-the-top, like some of the other big-fin options out there on the market. As always, our Mode Carbon Rear Diffuser will feature full tabs and utilize the factory mounting points for a seamless fit and finish that is guaranteed when you purchase any of our carbon fibre components.
Coupe Bootlid Spoiler: We are proud to present our first exclusive offering for the W205 C63(S) Coupe platform: the Mode Carbon Coupe Bootlid Spoiler. With a Mode Carbon product, you get that signature aggressive styling that is sure to be imitated by the masses. Our goal from the onset of designing this piece was to compliment the massive rear haunches of the W205 C63(S) Coupe with something equally aggressive and impressing. The lines of our Bootlid Spoiler accentuate the bold, robust flare of the wider body stance that the muscular Coupe flexes in the rear.
Hammer Down (08-29-2018)
Hammer Down (07-04-2018)
Coupe Edition 1 Front Splitter in stock and ready to ship!
We have launched our W205 C63s Coupe Collection on our website, please feel free to visit for more information regaring our most recent offerings for this platform.
http://www.modecarbon.com/model/w205-c63s-coupe/
Do you have any additional further out pics of this car? Especially a profile/side shot. Wanna see how that wing looks overall...
Mode Carbon (02-05-2018)
