Recall on rear axle diff mounting flange fracture?
I just got a recall notice #17V654 where, "during certain driving scenarios with high performance demands and low traction, the rear axle differential flange might become over-stressed and fracture. As a result, the vehicle may stall, increasing the risk of a crash."
The notice went on to state that the FIX for this was, "dealer will update the ESP and chassis control unit software on the affected vehicles."...
This sounds like they are simply going to increase the ESP control so that you can't break the tires loose as much? Hmmm....
Can anyone in the know shed more light on this?
2018 750i Msport, 2018 Range Rover Autobiography, 2019 C63, 2017 F Type R
I jsut had it done and it actually does not neuter the car off the line. What it appears to have done is make traction control less sporadic in kicking in and jerking the car to halt wheel spin. It seems the car actually lets the wheels break free a little more than it did before with traction fully on. I drive my car very hard all the time and can assure you I would be the first one to say if it neutered the car.
The following 2 users liked this post by black63s:
AMGSuperSaloon (11-29-2017),
BD-C63 (12-01-2017)
The updated software is designed to reduce wheelhop, not reduce power or launching speed, so it makes sense that the ESP logic is slightly less aggressive. As long as you aren't getting abrupt intervention, there shouldn't be a risk of breaking parts.
2012 C63 P30 Sedan
I'm pretty sure all the people that have had their mounting flange fracture at the drag strip had ESP turned completely off so I'm not sure what help the update is going to be.
I just had it done. There is also a suspension software update that is done at the same time. My car is a 2016 model. I'll play around with the car on my way home from work and give an update as to what I think
I had a chance to play around with my car last night after getting the software update and I like the car so much more. The car is in no way neutered off the line for whose who were worried. In my opinion the update allows you to have more fun with the car. When the traction control does kick in, its a lot less intrusive. Maybe that's what they were trying to accomplish. Maybe they had to much traction control dialed in and it was putting to much stress on the diff. I don't know just my 2 cents.
My rear diff mount snapped a few months ago. Accelerated hard out of a corner and the rear diff casing snapped. It spat out a driveshaft and some bearings. I assume I wasn't the only one if they're recalling for a esp software update.
Also, the newer esp software is much better than before in sport mode.
'15 C63S
I just had the recall update performed on my car. I wouldn't say the car is "neutered" by any means, but it definitely has a different feel to it. Not bad, not wrong, just different.
I drive with my car in Individual mode 99.9% of the time with the ESP set to Sport, so all I can really comment on is how this setting has changed. Before, if the rear end broke traction (either in a slide or going straight), it would let the slide happen pretty much unaltered (or at least it felt like that) but then would somewhat abruptly slow you down. It was no where near as abrupt as with ESP fully on, but it was still noticeable. If you didn't hit that hard slow-down point (ie. you drove within your limits or just slightly over), the ESP Sport setting seems almost as if it really wasn't doing all that much. Push a bit further, and you'd feel it kick in. And when it kicked in, it felt more like an on/off switch than true gradually application of ESP.
With the new software, I swear it feels like it's intervening right from the start. Instead of having the on/off feel it previously did, it now feels like it's able to partially apply ESP as needed. If anything it makes the driver look like they know what their doing when really it's doing the work for you.
This is just from the limited time I've had with the car (picked it up yesterday afternoon), so don't quote me completely on all this until I have more seat time with the new software.
And for those that might ask, my car is a '15 C63S sedan that still has all the original software except for this new recall update.
My car was updated as well when I went in for brakes and tires at same time. I needed pads at 9800 miles! I drive in individual comfort in sports+. Around town I'd always be in comfort mode. After the update its more pleasant around town in individual sports+ too. I just assumed the better drive was due to the tires because I had the Dunlop Maxx and they have horrible traction in cold temperatures and ride like crap. Anyway new Pilot A/S 3+ on, and the car is just smooth, and I don't feel ESP at all. But because I have traction now, I can't tell what the deal is. Safe to say it did no harm at all and may have helped a lot.
