C63s sedan drag radial?
Hello i am looking to buy c63s drag tires and rims. I am not sure of the space i have. The caliper seems so big i dont know how low you can go in the size of the mag.. anyone has done this and have an idea thanks!
the smallest rims available for C63 is an 18" and C63's is a 19" do to larger brakes. I don't know if there would be any clearance to go much smaller than that. Rear calipers are 14.2"
in front 19'' is the smallest you can go but in the rear im pretty sure u can go 18inch, i just want to know if anybody in here tried drag tire and rims with lower spec
On my 512whp/455tq W204 I used 16" clk wheels / 20mm spacers with 225/50 hoosier's, they worked awesome. Think I might try them on the 205, I'm sure they will fit as the new calipers are tiny compared to the 204's.
Originally Posted by dforman15
(Post 7410134)
there I fixed it for you |
yes Rotors. obviously not calipers. thank you
Good point, now that I think about it more.... the 204 rear rotor is 330mm vs the 205's 360mm....so yea definitely no go.
(Post 7410449)
time to downgrade rotors :) |
Originally Posted by mr747
(Post 7410469)
Racing comes first :)
Originally Posted by RDOCA
(Post 7411327)
All depends an what kind of racing you are doing.
