C63/C63S AMG
19x11 on a sedan with 305/30/19 tires
Old Apr 14, 2018 | 01:56 AM
JaeJin Sohn's Avatar
2015 W205 C63S, 2015 328i xdrive, 2008 Mercedes R-Class 350, 2009 Hyundai Equus
Smile 19x11 on a sedan with 305/30/19 tires
Hey guys, I managed to fit a 19x11 rims in the rear of my W205 C63S sedan. I believe I am the second person to do this on this forum as King Monkey? was the first person to fit a 20x11 on his sedan. His tires were 305/25/20 Pirelli P-zero which run skinny (lol) and he didn't share his specs as he got all his wheels from his friend's wheel shop. My specs are 19x9.5 +32 (with 3mm spacer) and 19x11 +60 (with 5mm spacer). The wheels are Forgestar CF5V custom offset forged monoblock wheels and the color is Bronze Burst.
Old Apr 14, 2018 | 02:55 AM
C3504matic's Avatar
2015 C63S ,DME Tune, KW Has ,Kmac Bushings,BC Forged wheels,Gt Rotors,Porterfield R4S,Modal Intake
Which springs are you using ? How much does it run i the rear ?
Old Apr 14, 2018 | 11:53 AM
Luis Tellechea's Avatar
C63 amg
Your car looks really nice with those Wheels
what size tires are you running for the fronts and backs?
why did you put spacers on the front? couldnt you go with the smaller offset up front or does it hit the suspension?
Old Apr 14, 2018 | 12:35 PM
chrisridebike8's Avatar
'10 C63
setup looks killer. but are your sure those are monoblock forged? I thought forgestar only made rotary forged wheels. even their site has the CF5V listed as "Rotary Forged Flow Formed Barrel"
Old Apr 14, 2018 | 03:04 PM
CF5Vs are Rotary Forged Monoblock Wheels. I am running 255/35/19 and 305/30/19 Nitto Invos. I have the KW height adjustable springs. The reason why I went with spacers is that not a single one on this forum has done a set up like mine and if they have, they weren't willing to share their offsets. I knew which offset I needed to go with without spacers but since I am the first one to try these sizes, I decided to go a little bit conservative on the offsets (by around 3~5mm) and space it out with spacers later. This conservative decision also took into account that maybe the wheels won't be exactly 60mm even if I asked for a 60mm offset since there could be some manufacturer inconsistency. Also, I am talking about a credit card gap of clearance with the struts, especially in the back which the fitment has to be at a perfect offset for it to work. I also had to shave off bolts inside my fender well so that it wouldn't rub against the rim and the tires.
Old Apr 14, 2018 | 06:19 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Looks killer
Old Apr 15, 2018 | 04:15 AM
RDO247's Avatar
C63S
Awesome mate, we need some close ups please.
Old Apr 15, 2018 | 08:34 AM
alexasa's Avatar
c
amazing, the rear are so good.
Old Apr 15, 2018 | 04:36 PM
size of the rear tire
had to shave this bolt down so that it wont rub
Old Apr 15, 2018 | 07:54 PM
C3504matic's Avatar
How do you find the Invo's ?
C63 amg
how much do they stick out past the fender? front and rears?
are they deep concave or super deep?
Old Apr 15, 2018 | 08:02 PM
I found the invos from discount tire direct
Old Apr 15, 2018 | 08:05 PM
AMG 17GT's Avatar
R Nine T
If you do any serious driving, that setup looks like you’ll sheer your tire/fender off.
Why wouldnt you go 1/2 inch less?
Old Apr 15, 2018 | 08:07 PM
C3504matic's Avatar
No I meant ....how do the info's feel compared to say the Michelins ?
Old Apr 15, 2018 | 08:08 PM
These wheels are just deep concave. You can see the specifications on Forgestar's website for which offsets are which face. The rears are sticking out a little bit when it's at a standstill but as the shocks compress, the wheels suck right in. However, there is no room for the rears to sit further inside as it's already rubbing on the fender liner (only the fender liner which is not a big deal). You can adjust the poke of the fronts using spacers or different offset wheels.
The fronts wheels are sitting at 2.8 degrees of negative camber from natural lowering and the rears are at 2.6 degrees of negative camber.
Old Apr 15, 2018 | 08:10 PM
I already have a different set up for my autox. These are just for the meaty fitment and aesthetic purposes.
Old Apr 15, 2018 | 08:14 PM
I honestly can't tell much difference from these to the Michelin PSS other than the fact that the tires got so much wider and that you feel more things on the ground as you drive. I can tell you that these are much better than the Dunlop Sportmaxx tires I had after my Michelins wore out.
Old Apr 15, 2018 | 08:31 PM
C63 amg
thanks for your help with sharing your offsets. we need more people in the forum like you you help others with their experiences.
Old Apr 15, 2018 | 08:47 PM
Ariesfamous's Avatar
2015 cls550
This exactly.
Old Apr 15, 2018 | 10:20 PM
Mr. Pink's Avatar
W205 c63s AMG
Awesome info thanks for sharing!
Are you all the way raised up in the rear?
I threw a 295 on my stock wheel and its super close but with +55 I could see this working.
Old Apr 16, 2018 | 04:31 PM
I'm almost as low as it can go in the rear. I got 10mm of perch left for the rears.
Old Apr 16, 2018 | 09:51 PM
darwin329's Avatar
w205 c400 c63s
Its good to see a sedan running 305 wide!! I wish i could run the same wide, unfortunately my wheel set up and offset only allows 295s on the rears am still happy thou hehe. Enjoy your new wheels mate!
Old Apr 16, 2018 | 10:50 PM
C63S8ABMW's Avatar
2016 C63 AMG S
I have to say I'm super jealous. I wanted to do 19x11 so bad. I wasn't willing to risk losing money on HRE R101's not the cheapest wheel to just try to make a custom offset work. So I went 19x10.5 in a +53 offset with 305/30/19. They will be going on tomorrow with K-Mac Camber kits. So we will see how it goes.
Old Apr 16, 2018 | 11:29 PM
KJ's Avatar
KJ
2020 GLE 53 AMG
How's the car handling with these tires?
Old Apr 17, 2018 | 12:21 AM
RDO247's Avatar
C63S
Can you put some pics up???
