Early brake pad sensor warning
2017 Mercedes C63s coupe
I have a 2017 C63s coupe with the ceramic brakes. My brake pad wear sensor just went on. Car has only 6800 miles and it has never been tracked. Is this an issue with an early sensor or does MB use such soft pads they were extremely early? Any input would be appreciated. Can you just replace the sensors if the pads have over 50% left on them.
Can't just replace the sensor, it will only wear the new one the same way.
Why don't you have someone inspect the brakes and find out why they are wearing so quickly?
