C63/C63S AMG
Aluminum side door panel corrosion
Old 09-23-2018, 09:16 AM
Alexpark911's Avatar
2015 C63 S EDITION 1/ 2015 BMW X5M
Has anyone experienced or noticed oxidation/corrosion to lower part or edges of aluminum side door trim panels?
Old 09-23-2018, 12:33 PM
ItalianJoe1's Avatar
2003 CL 600
The trim strip on the door or on the door skin itself? The trims do discolor, we have replaced a few sets under warranty. Notice it more on the night package cars usually.
Old 09-23-2018, 02:45 PM
These
Old 09-23-2018, 03:30 PM
2003 CL 600
Oh, never seen corrosion on the inside trims. They are always contaminated from outside influence or damaged when we have to replace them.
Old 09-26-2018, 02:16 AM
so I got a call from SA today, she said usually its not covered under the warranty..... however, they have not seen anything like that before and MBUSA agreed to replace all four under the warranty....hurray~~~
Old 09-26-2018, 09:30 AM
lovepower1's Avatar
C63 S AMG
Does anyone know how to remove this aluminium panel? Do you need to remove the whole door and loosen screws from the inside or can you use a plastic dismantling tool to take it out?
I have a replacement since mine is full of scratches, hence my question.
Any advice appreciated!!!
Old 09-26-2018, 09:42 AM
2003 CL 600
Pretty sure you have to remove the panel. Super easy to do on a 205 though, just 2 screws and it pops off, plenty of tutorials on here or youtube with pics/vids.
Old 09-26-2018, 10:25 AM
lovepower1's Avatar
C63 S AMG
Ah great, thanks! And i suppose there is screws inside to take out the aluminium trim itself? Found a tutorial on youtube for a w204 where it is like that.
Old 09-26-2018, 12:46 PM
2003 CL 600
I haven't personally done one, and a quick look through WIS didn't indicate anything useful. What does the new part look like? Some of them are melted on, some have press on clips, some have screws.
Old 09-26-2018, 03:11 PM
lovepower1's Avatar
C63 S AMG
Just checked the new part, seems like there is only clips (see pic) So actually removing the door panel may not be needed!
Quick Reply: Aluminum side door panel corrosion
