C63S- fittment of 20 wheels
Hi. New to this forum and just picked up the C63S sedan.
Hoping that I can fit a set of HRE P40SCs to them that I recently took off a car. However the specs of the wheels may prevent fittment.
20x9 +40
20x11 +52
please tell me there is a way to make them fit.
Note that they will also require an adapter as the wheels are 5x114.3
Many thanks in advance and awaiting the good news 🤞🏾
20x9 +40
20x11 +52
+40 in the frt probably won't work w/o rubbing bad on turns and definitely not a 11 in the rear ....it will hang way out past the body .I ran 20x10.5 + 52 and it rubbed on most bumps and I switched to +57 which was a far better fit
2017 Ford F250, 2018 C63s AMG Coupe
Sorry to piggyback your thread but I have a similar question...
Can someone please verify if these would work on a coupe?
9 x 20 ET 31
10.5 x 20 ET 55
My guess is yes as they aren't much different than stock. If they do fit, would I still need to run spacers to push them out to (near) flush?
9 x 20 ET 31
10.5 x 20 ET 55
So you're trying to adapt 5x114.3 wheels to fit your c63 with adaptors...………..no thanks!!
11" et 52 will not even come close to working in the rear...
