Downpipes install pricing
So far I’ve seen 800 mostly everywhere for cut and weld found an exotic ship near DC charging 1100 for transmission drop and install. What route is best and who has downpipes installed already? I tried the search function nothing popped up |
What?? I'd imagine it being about $400 for labor...
Originally Posted by skim7x
(Post 7675782)
Ive got the same here in South Florida around $800.
!! Forget that then... Not worth $2.5k for a little more noise and 30hp... 😪
(Post 7676480)
Originally Posted by Ryane8182
(Post 7676476)
I would drop the transmission if you were going to do it. A proper install should be about $800 to $1200 depending on hourly shop rate,
Originally Posted by AutoTalent
(Post 7676502)
I’m trying to figure out the best route for this |
In Houston. $500 with cutting the OEM down pipes.
(Post 7676502)
(Post 7680362)
why do to recommend doing the trans, aside keeping the OEM DP's?
Originally Posted by shardul
(Post 7679033)
Originally Posted by tysonn0214
(Post 7958740)
are you in Harris? Do you have to do emissions test with state inspection?
Originally Posted by ///Bruce
(Post 7958794)
Yes. You do. Full inspection. Unless you know someone....
(Post 7958823)
I thought that the car would have issues on the smog test with catless downpipes, but i guess that's not the case. I live in the country my county doesn't have to do emissions test, and the inspection only cost $7.00:). Secret tip, if you read the state rules, you can also drive to a non emission county and do your test, there are loopholes in it.
Originally Posted by OrientBlue3
(Post 7958854)
It definitely is the case in Texas. You will absolutely not pass an emissions smog test unless you know someone, like he said.
I know a place that can do them for $500.00 (Cutting OEM) here in south florida.
