Seeking opinions: Upkeep of black wheels? - MBWorld.org Forums
C63/C63S AMG
Old 02-09-2019, 01:44 PM
C63s Coupe
I am in the processing of ordering a new C63s, and debating whether to pick up the matte black wheels (767 option code) or just stick with the stock silver twin 5-spoke. I've never had a car with black wheels, and since black wheels seemsso common among AMG owners I thought I'd ask for your opinions on how often upkeep is required to keep them from not looking like sad brown wheels. I've also never felt the need to do any ceramic coating to maintain rims so this is all new to me.
This C63s will be my daily driver, and while I am not lazy on cleaning my cars I am also concerned I won't have a ton of time to dedicate to this task every week. For reference, I currently drive a 340i which looks pretty much exactly like this: https://f30.bimmerpost.com/forums/sh...daptive+cruise, and I don't find those wheels particularly hard to clean. If the matte black wheels are like that in terms of maintenance, then I will probably pick them up.
Thanks for your thoughts.
phoenixblue is offline
Old 02-09-2019, 01:57 PM
E55 KEV's Avatar
2016 GLE63s / 2016 E63s / 2002 E55
Look at it like this. If black painted cars are hard to keep clean so are black painted wheels. I have on 2 AMG's and they are more effort to keep clean. I love the look and don't regret getting them but MBZ brake dust is insane. I have tried a lot of wheel cleaners from Griots Heavy Duty to professional Mequiars Wheel Brightener (both acidic) and I still have to do manually cleaning on every spoke. I haven't found any spray on wash off wheel cleaner that performs as stated.
E55 KEV is offline
Old 02-09-2019, 02:12 PM
16' AMG C63S, 16' 991.1 GT3, '15 458 Speciale, 19' 4Runner TRD Pro
All AMG wheels will get dirty really quickly. It comes from the brake pads they use. A few hard stops and your wheel will get coated in a nice bronze layer of material no matter the color.
If you like the look of black wheels more, get them. If cleanliness really ends up being too much, swap your OEM pads for Porterfield RS-4 like many people on this forum.
obbob is online now
Old 02-09-2019, 03:20 PM
I put ceramic paint coating on my black wheels (just the cheap Amazon Mr. Fix9H stuff) and it makes them relatively easy to clean. I use a soft spit-end fine-bristle brush that has a plastic handle (to avoid scratching any car surfaces) and wash using Palmolive dish soap and water (I've used this for about 35 years on cars).
Applying the ceramic coating to the wheels is a bit of a pain because of all the corners and crevices ... and coating the crevices is very important because that's where the brake-dust tends to accumulate. My C43's wheels are "plasti-coated" (with what appears to be the Dupont product) and I also applied ceramic coating over the plasti-coat and they now come clean more easily (though the plasti-coat alone seemed to help, over just raw paint).
user33 is offline
Old 02-09-2019, 06:46 PM
Xec
2019 C63S Sedan
Just spent my first week driving my car and my matte black wheels have indeed become brown. Like others have said, that's just the nature of the brake pads. My red calipers look absolutely filthy. I think it might look even dirtier if I had regular silver wheels since it's less obvious on matte black.
I have a Feynlab coating on my rims that supposedly make them easier to clean. Will report back on this once it stops raining.
Xec is offline
Old 02-09-2019, 10:12 PM
2019 C63S Coupe - Graphite Grey Magno
I have the matte black wheels ... yes, brown brake dust collects and yes the MB pads do seem to throw a lot more dust than I've ever seen. But, I think the matte/satin finish of the wheels actually helps mask some of that. I have the graphite gray magno paint and though a very dark black it actually does quite well masking dirt, certainly better than typically gloss black. I'd say the same for these wheels.
I ceramic coated mine, not because of brake dust per se, but because they are painted wheels and wanted to protect them from acids, salts, etc. I use Dr. Beasley's matte wheel cleaner and the combo of it and the ceramic coating makes cleaning the wheels pretty easy. The "pain" has more to do with the fact that there are so many spokes, not because it's hard to get the brake dust off.
CrashTX is offline
Old 02-10-2019, 08:19 PM
C63s Coupe
Good points. Thanks everybody, I really appreciate the perspective.
Old 02-11-2019, 12:45 AM
P21s is the best imo... some of the wheel cleaners out there are crazy acidic.. p21s has a great formula... I use tardis for removal of tar that can build up on the inside of the wheel.. gets them like new. A detailer that charges thousands for a detail and flies from the UK to Dubai to detail hyper cars.. I trust him he. He always helped me out a lot when I emailed him for help when I started detailing my own cars. He does incredible work and more importantly super nice.. he has his own swissvax line of products too.. swissvax is on another level.. above zymol.. crazy expensive.
purplewidow is offline
Old Today, 08:57 AM
SPONSOR
EricAvalonKing's Avatar
Yeah, you're going to get a lot of brake dust - there's no way around it.
As some mentioned, ceramic coating will help. It will help a little with the accumulation as all have inherent anti static / stick properties, but really the biggest advantage at least in terms of brake dust is going to be ease of cleaning. Beyond that you will get protection from salt, corrosion, tar, acids etc etc.
For wheels, you definitely do not need professional application. Don't let anyone tell you otherwise. Application is simple just trickier with the spokes.
Any solid DIY kit will do but I wouldn't go with MrFix. 1. You'll probably have to wait weeks to receive it. 2. As it's a generic, the quality is going to vary massively. It's just a crapshoot.
EricAvalonKing is online now
Old Today, 01:07 PM
2019 C43 AMG COUPE
Regardless of silver or black wheels, frequency and cleaning methods should remain the same. Would definitely look into ceramic coating annually for easier removal of brake dust.
For me the choice between silver or black wheels ties into the character of the C63-S. Silver wheels give more of a high end classy look, adding to the shine and luxury of the AMG.
Where matte black wheels has more of a menacing premium black edition AMG design and flows distinctively with the gloss black and carbon fibre accents.
Carlo Cc is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Quick Reply: Seeking opinions: Upkeep of black wheels?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
