Removing Adhesive From Magno Paint
My 19' Coupe in Magno graphite is scheduled to arrive next month and i am slowly starting to order some mods. I am interested in the mode carbon rear spoiler, but I am wondering if it is possible to remove the OEM spoiler + adhesive on the magno paint without causing damage to the finish?
Please advise. |
I was just going to start a thread about this because I want to debadge my trunk. So I'll bump your thread instead, +1
Originally Posted by Vader C63S
(Post 7677938)
Please advise. |
Originally Posted by slowc
(Post 7678440)
I’d say heat and fishing line |
I'd say do a test area on the paint w/ the goo gone ....it's very easy to mark and a should you damage it a nitemare to paint . We end up painting the entire side if 1 panel is damaged including up into the roof rails
Would it be any different than removing badges on a non-matte finish? I use heavy test fishing line to remove badges then a 3m eraser wheel on my dewalt drill. Works like a charm.
Being brand new maybe removing the factory double sided tape might not be too difficult?? |
This video should help. Basically, it is the same process as normal paint, but as he notes in the video, don't use an eraser wheel. There is likely some difference in the paints used by MB compared to BMW, but I would think the overall process would be very similar. Just test a small, inconspicuous area first (as C3504Matic mentioned).
MAtte paint.... hmmmmmmmmm removing decal is easy.
Not damaging the paint finish since Matte would be hard. my guess is you will notice and not be able to do it. I mean read all the warnings about the paint. Ya have to be careful how many times you dry it etc as touching every time polishes paint and removes matte finish. Find a very good detail shop... or maybe talk to paint manufacturer first. Cause once you start there is no going back. |
Yup i think if i do go for the MC Spoiler i will have my detailer install it.
Though I shudder a little bit after-the-fact (now that I know) ... my detailer when I had the car PPF'd debadged my car and used Goof-Off to get the last bits of adhesive off. While I probably would've politely told him not to had I known in advance, it certainly didn't harm the paint. I think if it's used sparingly and the adhesive is removed gently (no hard rubbing to cause polishing), it does work without harming the finish. That's apparently what my detailer did and he's worked on lots of matte paints.
The #1 thing i'd do to a magno paint car is full PPF. There's absolutely no other way to protect that paint if you're OCD like me.
