c63s Daily Driver?
I am shopping 15+ c63 vs c63s sedans. Are there any major issues I should look for on a used example? Any major services? Realiability? I do drive 15,000 miles a year so I need something that is going to be reliable. My sister in law has a new c class thats ALWAYS at the dealer. I also will get snow tires for it as I drive in the northeast.
It seems I can get a nice c63 amg for around 37k, c63s cars are 40k+. Cross shopping with M3/M4 as well but getting bored of BMW.
Thanks everyone!
Thanks everyone!
As to the original question, my car is my daily and has been pretty much bulletproof. It likes tires and brake pads, especially rear pads, but otherwise it fires up and drives great no matter what. I’m a bit OCD about rattles and even with the convertible it’s quite pleasant.
I discovered when I open the sunroof to tilt position the rattling stops.
Last week had at MB dealership and lube sunroof tract. If it did not correct rattle I would need to leave car longer.
It stopped rattle for just a short time but it's back. It does not bother me too much but like to get it fixed.
. Does any else here had this issue? And please advise what you did to correct.
. Otherwise I love the car.
.But as far as a daily performance car goes, the C63 is one of the best. I'm a year and 12k miles into mine. However, the FL (2019+) has several improvements over the pre-FL, that make it a better daily. Specifically the revised suspension that makes it more comfortable and more compliant, while not losing any of the driving dynamics in Sport+/Race. But this ain't your average Toyota Corolla commuter car where you can rack up 10s of thousands of miles before you even need to think about tires and brakes. This is a 4000lbs GT/Sports Car delivering 450+ HP and torque to the rear wheels, so you don't have to be a rocket scientist to understand that this puts a lot of stress on the brakes and tires, and you'll have to change them frequently. So far my 2019 has been largely problem free. I had more issues with my previous car, a 2013 Audi RS5, during the first 10k miles. I mostly just did the first 10k service so far, plus a few things that weren't quite right from the factory. The car needed some software updates, had a faulty oil sensor from day one, and the biggest issue was that the aero package side sills started to fall off due to inferior adhesive used at the factory. While it was somewhat of a headache to get it resolved, it was nothing mechanical that I would deem as unreliable.
With my RS5 I needed new tires every 10k-12k miles, so increased wear isn't something unique to the C63, but I'm actually surprised about the tire life on this one. I think it's largely due to the all-new traction control of the 2019+ C63S, which primarily uses the engine management to control traction by regulating the engine torque, so the rear brakes and rear tires don't experience as much wear. I did change my stock PSS tires out for a set of PS4S at 10k miles, because my front alignment was off and it chewed up the inner edge of both front tires, but my rear tires still had more than half of the tread left. My rear brakes are also barely worn and I do drive the car hard whenever I get a chance. Everybody's mileage will vary, though, as wear has a lot to do with how you drive the car. The more traction control has to step in at least on the pre-FL, the faster you'll go through the rear brakes and the more you are hooning around, the faster you wear your rear tires.
I came from a GTR and that was just too compromising, though it did have a boot big enough for the pushchair. Since number 3 came along, I can get everyone in, including the 3 seater pushchair! (Mines an estate).
Considering an upgrade to an E63s, my only constraint was the wife having just passed her test, but I think she could handle a bigger car now. To be honest though, it gets us all in ok and I do like the C dimensions for our UK car parks, villages and B roads.
It's the best daily driver car i've ever had. It even clears speed bumps and driveways without scraping the chin and this really surprises me.
Just make sure your tires are inflated properly. Our forged AMG wheels are prone to bends and cracks (bent and cracked my two front 19/20 inch RXC wheels already whilst running 33psi and 32psi pressures)
With the AMG line (c63 and c63s) you will get a bit more road feel, which will translate to things in the car making more noise then in a super cruiser... but that is expected. Although by NO MEANS is it out of control.
Driving a ferrari around has noises too.. the stiffer you pin down the suspension , the more you will feel and then hear.
I noticed when I tires got worn down, I was hearing a bit more then normal, put new skins on, and all nice again.
my .02 worth
I love my car...I considered to have another daily but that takes the fun out of it, I dont want to look at the car and drive it on Sunday's.... I want to drive it because its what I like, so its my daily.
I just had a service done on mine, and they replaced all.. also they warrantied NEW calipers because the lamination had gotten clouding on them due to the heat from the engine.
(I think they are doing more warranty work, since they need the labor and work)
But on my C63s and C43 , we replace rotors and pads at the same time.. have been advised this by multiple people, but am sure its not 100% necessary..
We run the smack out of our cars as well.. I bought a performance car to do just that..
Its an AMG, its expected.. not a c300 ...
Your in South FL as well ?? I am in Boca..
