C63/C63S AMG
Tire Size
Old May 20, 2020 | 11:19 AM
theprototype's Avatar
24 AMG GT55
Tire Size
Just wanted to report for anyone out there with the 19” 5-spoke AMG front + rears that 275/35/19 front and 305/30/19 rear works great! Went to PS4S’ from my extremely ****ty Contisports. No rubbing, plenty of traction, even going over bumps feels better. My tire shop inflated to 34 all around even after telling them to go 33 front 32 rear. I had to drive for a few minutes to get the tire pressure to show so couldn’t tell them to adjust it, will have to do it myself later.
Since I had a hard time finding posts covering whether I could go 275/305 on my 19/19’s I figured I’d make this post. Hopefully it helps someone.
Old May 20, 2020 | 11:57 AM
mbny1234's Avatar
c63s
You have a coupe or sedan?
Hows it hooking up vs before? Any wheel spin on 2nd gear? Or 3rd?
Old May 20, 2020 | 12:18 PM
24 AMG GT55
2018 coupe. Haven’t gone too crazy since i just had them put on yesterday but so far hooks quickly in 1 and no noticeable wheelspin beyond that. I’ll warm everything up and try some WOT today.
Old May 20, 2020 | 01:09 PM
mbny1234's Avatar
c63s
I have a sedan and don’t think anyone has 305 rear with 19s. I know some of the coupe have 19 and 20 rears.
Next I will go 295 rear, 275 fronts probably AS 3+ because ny weather and I drive all year round.
Old May 20, 2020 | 02:00 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Good to know it works without issue as that's what I'm going to put on once I need new tires. Are you running any spacers?
Old May 20, 2020 | 02:16 PM
24 AMG GT55
Nope, no spacers needed.
Old May 20, 2020 | 02:42 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Perfect. Thank you.
Old May 20, 2020 | 04:51 PM
SimMB's Avatar
C63S
What width are 19" coupe wheels? Are they cross spokes?
Old May 20, 2020 | 04:52 PM
tobeit's Avatar
AMG C63s
not 19's but there are a few who have 305's on sedan....just not on the 19" OEM wheel.
Old May 20, 2020 | 05:03 PM
raudiace4's Avatar
19 E63s, 23 M3 compX, B9 SQ5
Nice OP. I just ordered a new set of PS4s for the rear 295/30/20 to replace my worn set. I can't fit 305s bc i'll rub too much with my wheel setup/lowered height.
Old May 20, 2020 | 05:27 PM
mbny1234's Avatar
c63s
Right, assume you can go 305 rear with 18” OEM on c63 non S, as 18s would not clear the brakes on S model.
Old May 20, 2020 | 06:00 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
I have the forged cross spokes on mine. They're 19x9 in the front and 19x10.5 in the rear.
Old May 20, 2020 | 07:01 PM
BrianShaw23's Avatar
2019 AMG G63, 2020 AMG C63s Coupe
You guys think I'd be able to go 275 front 305 rears on my 2020 C63s Coupe? I have the staggered 19 front 20 rear setup. I currently have Cup 2s installed in stock size (255 front, 285 rear) I really like the Cup 2s, especially after they break in and weather is warmer now than when it was cold when I picked up the car. Just a matter of how many miles I can get out of the Cup 2s, if I gotta replace them at 10k miles then prob going PS4s lol.
Thinking 275f 305r setup would look pretty good on the car.
Old May 20, 2020 | 07:16 PM
24 AMG GT55
Yeah, that's been done before. So basically for the record you can run 275 / 305 on any of the stock W205 coupes. Just make sure to inform the shop to deflate to 33 / 32 and you won't have any problems with rubbing. But even at 34 all around right now I've not had any rubbing.
Old May 20, 2020 | 07:22 PM
Nice, no rubbing even when the tires heat up and the tire pressure increases? I run my tires 33 rear, 35 front but when the tires get hot the fronts get around 40-42 and the rears around 36-38 psi.
Old May 20, 2020 | 08:08 PM
24 AMG GT55
So I drove around for a good hour today with no rubbing and it was 93 here in Houston
