New C63S AMG Owner
I’m a new owner to a C63S. Loving the car so far however find the rear abit wild.
Currently got Michelin PSS that need changing, what is the recommended tyre and also what size? I’ve heard people talk about increasing the rears etc. Any help would be appreciated. Thanks
Also, get used to rolling into the throttle.... stamping on the throttle will force it to down change in auto mode and with cold tires, it will spin the rears. Roll into the throttle and let the torque build and its a lot more controllable. Or, use it in manual mode and just manage the gears / response from there. A little bit of an adjustment in your driving style and you will be really surprised in how quickly you can drive without breaking traction.
Finally, I find that the car does manage the traction pretty well. A little loss of traction is fine and with the e-LSD on the S does handle it well. Its engineered to be a little lose but controllable.
Thanks the response, yeah I noticed its not like my previous car which was an Audi RS3. Got to feather the throttle abit more than that! But its all good and exciting!
The front two tyres have abit of life left, i was thinking changing the rear two to M4PS’s. Would you recommend changing all 4 or will 2 be okay?
Do you have a sedan or coupe/vert? The coupe/vert have more rubber in the rear and a wider track and different suspension/rear axle, so they manage traction a bit better than the sedan with its narrower track and tires. You can put wider tires even on the sedan if you want more rubber to keep you on the road, but as recommended above the PS4S has all the PSS offers, but much better. It offers the best overall wet and dry traction balance and IMO is the best every day street performance tire. There are other tires that offer more dry grip/performance, but generally they need to be warmed up and/or have reduced wet traction. I went from the stock PSS to the PS4S on my '19 coupe and the difference is very noticeable. For me the PSS was a step backwards, because I had put the PS4S on my RS5 before I sold it. Once you drive them back to back you don't wanna go back to the PSS, IMHO.
I have brought a 2016 Sedan, I read up on the coupe being better etc but I prefer and need the saloon for family life and yes family life in an AMG!
Currently the car has 265s at the back, I was told it might be better to upgrade to 285. Is that what you have?
