C63/C63S AMG
Jb4 issue
Old Nov 29, 2020 | 12:44 AM
sleeperc63's Avatar
2020 C63 AMG
Old Nov 29, 2020 | 01:11 AM
ansonkk1's Avatar
2019 C63S Coupe
Old Nov 29, 2020 | 01:23 AM
sleeperc63's Avatar
2020 C63 AMG
Old Nov 29, 2020 | 04:45 AM
ansonkk1's Avatar
2019 C63S Coupe
Old Nov 29, 2020 | 09:56 PM
GLCya63's Avatar
2020 AMG GLC 63
Originally Posted by sleeperc63
Any idea on why the gauges in the app won’t work?
You need to download and install latest firmware for 2020+ C63.
in the user settings, search for the firmware update option and look for the 2020+ C63 file.
Old Nov 30, 2020 | 01:17 PM
sleeperc63's Avatar
2020 C63 AMG
Old Nov 30, 2020 | 07:24 PM
BMS's Avatar
BMS
Former Vendor of MBWorld
2018 C63 Sedan
Yes 2020+ and older models use different firmware, easy fix within the app via an update.
Old Dec 5, 2020 | 07:01 PM
Erik Apple's Avatar
2018 C63
On 2020 c63 sedan jb4 installed with Bluetooth connect. When I turn the car on it gives me this message and the gauges in the jb4 app don’t do anything:
mercedes me connect services limited see operators manual
Burgers troubleshoot said check the obd connection I did and it’s still showing up so I just unplugged from the obd from now I don’t see a point of keeping it plugged in anyways tune still works. Any ideas on how to fix it?
How do you like the tune? I just got a 2018 C63 3 weeks ago
Old Dec 5, 2020 | 07:36 PM
sleeperc63's Avatar
2020 C63 AMG
Old Dec 5, 2020 | 08:21 PM
Erik Apple's Avatar
2018 C63
I like it I’m only running map 2 so not a big difference but now I’m pushing 500 hp is my guess I noticed a difference in throttle and speed the car is more tail happy now and i don’t know if it’s just me but I think it made a difference in exhaust sound too a little bit louder
So I assume you would recommend it? Im not interested in running a ton more boost or race gas. I think I would maybe change exhaust and try the JB4, Thoughts? Im also told you can undo the tune and nobody would know you had it on, therefore keeping your warranty intact?
Old Dec 5, 2020 | 08:47 PM
sleeperc63's Avatar
2020 C63 AMG
Old Dec 5, 2020 | 08:54 PM
Erik Apple's Avatar
2018 C63
Yeah I recommend it. If that’s the case you can just use it in stage 2 and get performance gain. It is a plug in tune so it doesn’t flash the ecu if you remove the equipment no one will know it was tuned and it will be back to stock. I recommend investing in the Bluetooth kit and mobile phone application to make life much easier. I’m probably going to try mixing e85 fuel to run a higher map and see If it’s worth it
Im down to get the bluetooth kit, but do I need it if Im not changing and playing with **** too much? How much would I gain with stage 1 or 2 if I left everything else stock?
So you are gonna add the extra tank for the E85?
Thanks by the way!
Old Dec 5, 2020 | 09:05 PM
sleeperc63's Avatar
2020 C63 AMG
Old Dec 5, 2020 | 09:10 PM
Erik Apple's Avatar
2018 C63
I may be wrong but I believe if you don’t buy the Bluetooth kit and plug it in on its own it will default be map 2 I would research more into that though. The jb4 runs on maps not stages I was mistaken with that too. From what I’ve read to run the e85 on these cars you use 70% 91 fuel and 30% e85 mix in the same tank
OK thanks,
Any idea on the HP gain with Map1 or 2 and everything else stock?
