Those who listen to their own MP3s: quickest way to skip tracks while in NAV mode?
And I was also happy to find there's a shortcut to skip tracks so I don't have to switch from NAV to MEDIA modes: swipe up with two fingers, then swip left or right to change tracks.
My issue is that swiping up with two fingers doesn't work for me about 20% of the time. It will just recognize one finger and change the zoom level of the NAV map.
Is there an easier way that I haven't yet discovered? I like having the map up, but I'd also like to easily skip tracks at the same time without swiping 5 times. These are the often the only two things I use on a drive, and yet Mercedes seems to have made it overly complicated.
Or just bring it up on the dash and change with your steering wheel.
This btw is why I use carplay. You can have your map with directions on the same screen as your music controls.
When you say, "bring it up on the dash and change with your steering wheel," could you elaborate? Sorry, I'm rather new to the car.
And I've really got to try Car Play, thanks for the reminder. I was thus far undecided whether or not it would be an improvement over the existing system, but this use case might be the deciding factor.
Once you have that as your dash display you should be able to use the arrows to change the track
Do you, by chance, know if there's a way to have both the map on the instrument cluster and still have a tach? I could well be missing a simple way to keep both.
