Stages 2 issues
stage 2 is a mad fckery in total i've seen 3 guys posting about blow their engines on the aussie c63 group on facebook both stage 2 both tuned at international autohaus the other one tuned stage 2 off the shelf.......
looking more into it these guys mentioned injector failure cause piston to do something blah blah.........
anyway
DON'T DO STAGE 2
anyway
DON'T DO STAGE 2
That's how I got my motorcycle tuned, on a dyno with a professional who knew what he was doing, and I've had no issues. I'll definitely be going that route with my much more expensive to fix C63 when the time comes.
anyway
DON'T DO STAGE 2
I’m having problems with misfires and some other members as well but it generally sounds like a small problem to fix. I’m the second owner so who knows what fuel quality the first owner used. Its not like we are out here breaking axles or blowing transmissions left and right. Just need some injector cleaning, maybe a fuel pump and some new sparks.
but I think you're overreacting a lil…
I have the Renntech HHT. Is that considered stage 1? They don't even have an option for stage 2.
They have the "regular tune" and the "intermediate" tune which they recommend for 91 octane fuel locations.
So back to my original question. Is the regular Renntech HHT tune stage 1?
ECU is then tuned (TCU tune not required with Stage 1 at all but is optional if you want a bit more torque).
BMC panel filters are an ideal upgrade too but not required.
Stage 2 - You'll need Downpipes + Intake (minimum) for Stage 2 ECU & TCU Tune to be done.
Bit concerning aye but most likely a tuner issue as all cars I've seen have come from the same garage.
Personally there's not much need for anything more than stage 1 and 600hp at the crank. Even stock power is quite brutal.
I don't even know why you'd need more than 600hp in this car with all the traction issues anyway.
I'm happy with mine at stage 1. As noted, stage 1 whether off the shelf or custom dyno tuned is the safest out of all tunes for these cars unless you're going all out with a proper rebuilt etc etc
Last edited by Jimmy_c63s; Mar 17, 2022 at 09:28 AM. Reason: Added some more details
I also feel the Renntech HHT is pretty reliable from what ive read.
Im sure issues can develop with anything though.
My understanding is you can put dpwnpipes on these cars and not tune them (sound only from what ive read)....whether stock or stage 1. However if you tune a car with downpipes, its considered stage 2.
Is that accurate?
You can get the CEL coded out though or use O2 spacers.
If you don't want to tune, best to get catted downpipes. Less cabin smell, too.
No plans now to go any further then I have, but I've toyed with catted DP for some sound. Just not sure its worth the cost and possible headache.
