Rear Brakes Squealing
yeah its the rear, mainly the rear left
they squeal when you gently press the brakes when coming to set of lights, if firmly pressed they wont squeal
i have not measured the rear pads
Last month the Check Brake Pad light came on and needed rear rotors and brake pad replaced. The Dealership bedded in the brakes for me.
I believe it had just under 18,000 miles.
No more squealing. What a pleasure.
https://porterfield-brakes.com/produ...-s/ap1669-r4-s
What I noticed during the change is the OE pads have a separate/second metal backing plate between the pad itself and the caliper pistons/boots. This, mixed with the lack of anti squeal paste will result in noise.
After swapping in the porterfields, no more noise. You could add those to your rears.
the OE pads were always squealing and I couldnt stand them even though their initial bite was stronger
I might give these a go, hows the brake dust on these?
