C63/C63S AMG
Rear brake rotor
Old Jul 6, 2023 | 11:33 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
Rear brake rotor
Does anyone know if the rear rotor for the c63s and C63 are the same? I know that the front rotor are differently different in sizes between the two models. Thanks
Old Jul 7, 2023 | 03:26 AM
superswiss's Avatar
2019 C63CS
They are the same dimension, but not the same rotors. The C63 rotors are drilled, whereas the C63S rotors are drilled and slotted. Same for the fronts. Non-S are drilled and S are drilled and slotted. Below is a pic of my new Zimmermann rear rotors, but they are identical to the OE S rotors.
Old Jul 7, 2023 | 12:25 PM
Klinh's Avatar
Thanks for the infos. My car with 40k miles and needed rear pads and rotors replacement so I bought a completed oem rear kits from FCP Euro because they have a lifetime replacement free. Saved me $500 vs buying from the dealer. Dealer only charges $375 for installation so I let do the installation.
Old Jul 7, 2023 | 12:35 PM
superswiss's Avatar
2019 C63CS
Yes, I bought the kit from them as well, but with the Zimmermann rotors. Looks like the price went up slightly. I paid $646.34 for the kit in February. I have their front kit with the Brembo full floating rotors as well. It's the second set, and got a full refund for the first one, so parts were free.
Old Jul 7, 2023 | 01:00 PM
W140King's Avatar
W140 S320
Does anyone have the part number for the rear 2 piece brembo rotor?
Old Jul 7, 2023 | 02:33 PM
Klinh's Avatar
I can saved another $400 by going with none oem parts but the dealer won’t install none oem parts.
Old Jul 7, 2023 | 03:00 PM
superswiss's Avatar
2019 C63CS
Find a good indy in your area. I don't go to the dealership for a brake job. Brakes and tires I get done at my indy. But I did have a tire replaced once at the dealership. I bought a non-OE PS4S and they mounted it with no fuss. Still don't know if they actually road force balance. I suspect they don't, which is partly why I get tires done at my indy. They road force balance them.
