C63s shaking/ pulsing on idle
any guess on what it could be????!
it’s wouldn’t be a vacuum like or a boost leak right??
:spark plugs and coil packs were recently done also
- COMFORT or SPORT mode (when the idle is lower)
- Fuel tank us under half
- I haven't driven it for 2 or more days
Does this sound familiar to you? Or does yours just "skip" all the time, every time?
To explain it, if I'm stopped at the lights and in COMFORT mode or SPORT, i'll feel this quick pulse through my foot as I'm resting my foot on the accelerator (I use the brake HOLD) often.
The sound basically goes "TUG" and you can feel it through the pedal. Then driving the car it'll be perfect and not happen again for a while. But sort of makes you wary of it until it happens again.
No CEL or errors so far.
Is that it?
Only when the idle is like this
Is that it?
- Coil
- Vacuum leak
- Injector
- Bad/stagnant fuel
But a bad injector will have a CEL and a telltale sign it's an injector is keep an eye on your ECO START/STOP button on the console. If it fails to light up and won't work, the injector is on it's way out and it's time to get it tested or change it.
So I'm kind of stumped at the moment 🙁
- Coil
- Vacuum leak
- Injector
- Bad fuel
A telltale sign it's an injector is keep an eye on your ECO START/STOP button on the console. If it fails to light up and won't work, the injector is on it's way out and it's time to get it tested or change it.
how can I check for a vacuum leak tho?
have you took ur car to a mechanic or dealer to get it looked at for the problem?
- Coil
- Vacuum leak
- Injector
- Bad/stagnant fuel
tried it out today and the start/stop button works
