C63/C63S AMG
Belts and pulley replacement
Old Jan 11, 2024 | 06:50 AM
gforc3's Avatar
C63 Coupe
Hello all, my car has been making a slight squeaking sound when cold starting for a while now and it goes away after driving for a bit. From everything I've read here it looks like the belts, tensioners and pulleys probably need to be changed. I attached a screen shot of the parts I believe I need but I want to double check with you guys if thats it or I'm missing something.
Thank you
Old Jan 11, 2024 | 11:22 AM
jopsis_c63s's Avatar
C63s Estate
I changed the last year.
My recomendation, replace all on both sides.
Regards
Old Jan 11, 2024 | 02:16 PM
raphman's Avatar
'16 C63s
Mine started doing this as well last year, with about 70k miles on the clock. Took it to an indy shop and they did all pulleys, belts, and tensioners for $1250
Old Jan 14, 2024 | 02:53 AM
sikodk's Avatar
kia Roy
I would look into replacing the engine coolant reservoir. It's one of the things commonly known to fail due to leakage. Then the charge air cooler and your set.
192.168.100.1 192.168.1.1
Old Jan 14, 2024 | 03:14 AM
gforc3's Avatar
C63 Coupe
Thanks for the responses. Can anyone tell me if the parts I have in my cart are all I’d need or if I’m missing anything
Old Jan 15, 2024 | 09:24 PM
raphman's Avatar
'16 C63s
Sorry, can't assist there since the shop did all the work; they just gave me the quote and I gave them my credit card #
