Oil leaking intooo where?
I am going to fill some more oil (which I can vacuum out the dipstick if I need) and see if the oil is indeed low. The question is, if it is low, where is it going? I took down the trans cover after the first refill and there was no oil leaking from below. If it's not low ... accidental warning message? Oil level sensor faulty?
I was able to check the oil level on a warm engine and flat surface. Can say now that it was an extraneous warning as the level is correct. I definitely panicked a little bit the other day because last month the oil level was indeed low when I got the warning and I figured it was a legitimate alert this time too.
Thanks for taking the time to respond everyone.
