C63/C63S AMG
Extreme + fuel trim bank 1 (positive lean)
Old Sep 4, 2024 | 07:29 AM
Revtuners's Avatar
m177
Hello everyone
Had this c63s come in a 6 months ago, we diagnosed an 02 sensor fault, leaking pcv (both banks), leaking purge and we checked diverter valves and saw they had started shredding plastic into the turbo's. At the time the customer did not want to proceed with anything except the 02 sensor (went overseas or something).
Customer came back today complaining of an intermittent 02 sensor code (not sure as no codes on dash and 02 sensors are working fine). We replaced the diverter valves and plugs (they were passed due). Complained of an intermitten cold start misfire that goes away.
After it warms up bank 1 starts heading into the +80% fuel trim range and sounds very rough. We are going to replace the oil separators and purge.
How common are injectors on this model? We have not had to change one yet on these motors. We can test them but customer doesn't want to pay for it just yet, same old story.
Old Sep 5, 2024 | 08:54 PM
Fluffy Nuggets's Avatar
2018 C43 Coupe
Originally Posted by Revtuners
Hello everyone
Injectors are a common issue on the M177. Not sure if this specific issue are symptoms of a bad injector but any misfire its worth checking coil packs and injectors since you already replaced plugs.
Old Sep 6, 2024 | 05:20 AM
Jimmy_c63s's Avatar
Hello everyone
It's the injector.
Old Sep 10, 2024 | 11:33 PM
Dr.Ron's Avatar
C7 Z06
I got a cylinder 7 misfire while I was on the track. It only happened that 1 time.
Should I be concerned & should I do anything about it at this point?
Ron
Old Sep 11, 2024 | 01:14 AM
Jimmy_c63s's Avatar
Ron
What was the level in your fuel tank when it happened? Full?
Old Sep 11, 2024 | 08:43 AM
Dr.Ron's Avatar
C7 Z06
No, probably around a half tank +/-.
