C63/C63S AMG
C63s -P00178 - Crankshaft position correlation with exhaust camshaft position (bank 1
Old Dec 11, 2024 | 03:57 PM
Kh99's Avatar
Hi everyone on the Mercedes forum! I'm new here and have turned to you because I'm stuck on what to do with this car. I have a 2017 Mercedes C63S with 96,120 km on the clock. The car has been running perfectly, but suddenly, it threw the following error codes:
  • P001785 – Crankshaft position correlation with exhaust camshaft position (bank 1)
  • P030022 – Random/Multiple Cylinder Misfires Detected
  • P030485 – Cylinder 4 misfire detected
  • P030285 – Cylinder 2 misfire detected
The misfires are only occurring on the passenger side of the V-engine. I’ve tested the sensors and checked the wiring, and everything seems intact. In the live data, the reading is always showing -32 degrees, regardless of whether the connector is plugged in or not. When I disconnect the other side of the exhaust camshaft, it also shows -32 degrees, which makes me feel like the right side isn’t receiving the signal from the camshaft reluctor ring.
I’ve also tested the camshaft solenoids, and both show a resistance of 9 ohms and click nicely. My question is really: Is it normal to need to replace the camshaft? When replacing the camshaft's VVT (Variable Valve Timing), does the reluctor ring come with it, or is it a part of the camshaft itself? According to the picture I’ve attached, it’s mounted on the camshaft, but I don’t understand why I’m not receiving any signal from it.
https://nemigaparts.com/cat_spares/e...asis=205487C42
Thanks for your help!
Old Mar 20, 2025 | 06:26 AM
Dwarf's Avatar
A45amg
I have the same symptoms. Did you succeed in this problem??Exhaust camshafts, augusts, magnets, and solenoid valves were replaced. -32 degree fixed with p001785 left
