C63/C63S AMG
PERFORMANCE AMG - YET NO FRONT OR REAR CAMBER ADJUSTMENT
Old Feb 21, 2025 | 02:21 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes AMG conjures up “Performance”. But reality is still a “mass produced” vehicle with
speed of production - cost / efficiency still the underlying criteria !
Hence still soft rubber suspension bushings and no Front “Camber” and “Caster” or
Rear Camber adjustment - only basic Front and Rear ‘TOE’ - directional adjustment
But essential to be able to dial in extra neg. Camber for performance handling or Track days.
Dramatically reducing understeer - deeper into the corners with increased traction and braking response.
Yet just as essential for day to day commuting - having the advantage of ongoing individual
adjustment to cater for varying road or load conditions. Allowing adjustment of tire contact
angles to spread load more evenly therefore resolving costly, premature excess edge tire wear.
K-MAC kits are also designed to require no special tools or
time consuming need to remove control arms to install !
Plus Unique Patented Design also allows ultimate adjustment -
Easily accessible, single wrench - direct on alignment rack UNDER LOAD !
Both Front and Rear adjuster kits - bushings are also “uprated” for
Performance handling and significantly improving Brake and Steering response !
DHL Express Air $40 one kit ($20 each extra)
sales@k-mac.com ….web: www.k-mac.com ….1888 847 9099 (Sales Tech 24/7)
W205 ALL INCL. C63/S AMG SEDAN, WAGON, COUPE.
*ALL K-MAC KITS P/N IS FOR “BOTH SIDES”
K-MAC - ALSO “UPRATING SAME TIME” THE 4 FRONT AND REAR HIGHEST WEARING BUSHINGS -
FIXING IT RIGHT THE 1ST. TIME. UP TO 2 EXTRA DEG’S POSITIVE OR NEGATIVE CAMBER.
W205 FRONT SUSPENSION
FRONT KITS STARTING FROM $345 (LESS COST THEN 1 QUALITY TIRE) !
C63/S AMG CAMBER (ONLY) #503316-1i $345
CAMBER & ALSO CASTER #503316M $595
C180-C350 CAMBER (ONLY) #502816-1i $345
CAMBER & ALSO CASTER #502816M $595
C200-450 / C43 AMG CAMBER (ONLY) #503416-1i $345
CAMBER & ALSO CASTER #503416M $595
ABOVE CASTER BUSHES - K-MAC are Mono ball / Self aligning replacing the OEM large diameter soft rubber bushings
still allowing arms to travel through their required suspension arcs but significantly improving Brake and Steering response.
REAR KITS CAMBER (& EXTRA TOE)
COIL SUSPENSION Sedan, Wagon (incl. C43 C63/S AMG) #502226K $480
COIL SUSPENSION C63/S Coupe #502326-1K $480
REAR UPRATED ‘6’ MULTI LINK ARM BUSHINGS SEDAN, WAGON #502628K $480
(Less Twitch, Flex, Wheel tramp / loss of traction - Especially when applying power to lane change / overtake) #502326-3J $380.
REAR UPRATED TOE ARMS - PREVENT FLEX TOE CHANGE WHEN CORNERING (Sedan & Wagon - not necessary C63/S Coupe).
*Also manufacture rear adjustable Upper Camber Arms - But more difficult to fit & adjust.
AUDI to VOLVO - Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964
Old Jun 23, 2025 | 08:26 PM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
I can vouch for these guys. Their kits are game changers when it comes to being able to add some negative camber for MUCH better track performance. I just went with their upper front kit and was able to get right at -2.5 degrees on each of the front wheels. That alone knocked several seconds off my lap times at Thunderhill and corrected so much of the understeer. The car no longer feels like a pig on track. Probably the single best bang for your buck mod you can do for these cars. Seriously guys, these kits are worth it.
Kurt
