C63/C63S AMG
C63s no boost problem
Old Aug 22, 2025 | 09:09 PM
C63sB's Avatar
C63s
Recently, my 2019 stock C63s has been acting up in 2nd gear. Sometimes it won’t build boost and won’t push full power past 3k RPM, but other times it’s fine. 1st gear pulls normally with no issues. (there is no check engine light the car sounds and feels fine)
Has anyone else experienced this? Could it be related to needing a transmission flush, or might it be something else?
Old Aug 22, 2025 | 10:32 PM
superswiss's Avatar
2019 C63CS
First things first. Hook up a proper diagnostics tool and see if it logged any error codes, then take it from there. Everything else is guessing.
Old Aug 27, 2025 | 07:51 PM
C63sB's Avatar
C63s
Looks like there's no hidden error codes, i just got a oil change and a transmission flush and its still not pushing full power...
It sometimes does and sometimes it doesn't no boost
I think there might be a really small boost leak
Anyone have this issue before??
Old Aug 27, 2025 | 08:49 PM
kvirikadzed's Avatar
I seem to have similar issue , I’ve had my stage 2 for past 3 years no issues and 2 weeks ago I started to notice similar issue . I ve checked in xentry and exhaust valves seem good , I changed boos vacuum solenoid and plastic vacuum tube, but it still has the same problem. It barely makes any boost , I’ll be taking to mechanic next week to check …
Old Aug 27, 2025 | 11:33 PM
C63sB's Avatar
C63s
yeah i have no idea what's going on with this car, just took it out tonight weather is cold nice boost weather and the car was pulling nice with no issues lol
Like i said sometimes its fine sometimes it just drives with no boost/power after shifting gears
Old Aug 28, 2025 | 12:31 AM
superswiss's Avatar
2019 C63CS
Those are the worst problems to fix. Intermittent and nothing logged.
Old Aug 28, 2025 | 10:31 PM
jj18's Avatar
2019 C63S Coupe
Old Aug 29, 2025 | 07:27 PM
C63sB's Avatar
C63s
Yup used a better tool to read codes and it gave me a MAF sensor , i think that's what's causing the car not to push power
Gonna clean that sensor and hopefully problem is fixed
