C63/C63S AMG
AMG OLED Steering Wheel Button Change
Old Sep 11, 2025 | 02:57 PM
Tattooedashc's Avatar
GLC63S and C63S
I have a 2020 C63s with the AMG wheel with the AMG OLED buttons.
The steering wheel has seen better days so going to swap over for a carbon fibre one.
Question is can the original OLED buttons be switched over without issue? I have seen retro kits to fit, but mine is the original kit that I need to move over to a non OLED model.
Old Sep 11, 2025 | 03:56 PM
superswiss's Avatar
2019 C63CS
Yes, as far as I know as long as you get the correct SKU for the steering wheel that has the proper bezels and steering control unit. The retrofit kits come with those, so you can replace the bezels etc. in order to mount the units and the steering control unit so they work.
Old Sep 11, 2025 | 03:59 PM
GLC63S and C63S
Great thanks. Was just worried it wouldn't fit and didnt want to pay ££££ for a wheel which wouldn't accept them
Old Sep 12, 2025 | 10:04 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
as long as you get a carbon wheel facelift 2019 you’ll have the screw holes for the drive unit. I’d say 99% of the carbon wheels out there use a core that can accept a drive unit so should be safe. All the core we use at least allow adding that option. I circular the holes so you can see where it attaches
Old Sep 13, 2025 | 03:51 AM
GLC63S and C63S
perfect thanks very much. Ill check with seller.
Old Sep 13, 2025 | 04:13 AM
japamg's Avatar
Final Edition C63s / RS3 Sportback
I have just changed mine for same OEM steering wheel, it is plug and play no issues with oled buttons
Old Sep 13, 2025 | 04:14 AM
GLC63S and C63S
this is the one im looking at, I suspect you cant tell if facelift core?
Old Sep 13, 2025 | 06:57 AM
japamg's Avatar
Most important thing you need to check is if you have this gap to fit the oled buttons
Old Sep 13, 2025 | 07:12 AM
GLC63S and C63S
Cheers, ill reach out to seller and get him to check
Old Sep 15, 2025 | 10:47 AM
lthlc63's Avatar
there are different trims not cores. The trim will have a cutout to allow the mounting of the drive unit
Old Sep 15, 2025 | 10:48 AM
lthlc63's Avatar
impossible to tell with the trim mounted. All the cores look identical on the outside
Old Sep 15, 2025 | 11:25 AM
GLC63S and C63S
Yeah he wouldnt take apart so gonna have one made up instead using my VIN, so least I know it will fit.
Thanks for all the replies
