C63/C63S AMG
Brake Pads
Old Mar 17, 2026 | 06:37 PM
fledda's Avatar
Mercedes Benz SL63, C63S, Jeep SRT8
Brake Pads
Has anyone used Textar brake pads. If you have, what has been your experience with them from a performance perspective vs oem as well as dust level. Thanks
Old Mar 18, 2026 | 02:23 AM
C63s_Jack's Avatar
AMG C63s Coupe
performance i would guess like oem.
dust allso. i guess they are near to oem.
i have no doubt to the braking performance oem as textar. if you by textar check out that you not buy them from cc disks if you have steel discs !
if you want racing pads buy racing pads.
Old Mar 18, 2026 | 07:33 AM
fledda's Avatar
Thanks. I am buying them as a replacement for the own. I am looking for an oem performance and low dust.
Old Mar 18, 2026 | 07:50 AM
fledda's Avatar
Textar has a kit that includes brake sensors. The brake kits they have is based on the color of the calipers. I have a C63S which are steel rotors.
This is what I found.
Old Mar 18, 2026 | 08:55 AM
C63s_Jack's Avatar
AMG C63s Coupe
write @ to textar support , tell vin.
they give you the right # number.
i would not ask KI for this.
you can use textar online parts catalogue too but better you make a @
its allways good to know oem mb part number allso checked by vin. than you can compare.
( double check by your self)
Old Mar 18, 2026 | 09:00 AM
fledda's Avatar
Thanks. Yes the seller needs my VIN number to make sure it fits.
Old Mar 18, 2026 | 09:01 AM
C63s_Jack's Avatar
AMG C63s Coupe
look above i updated what you quote.
Old Mar 18, 2026 | 09:05 AM
fledda's Avatar
look above i updated what your quote.
Thanks. Yes I will do my due diligence.
