C63/C63S AMG
Window Regulator?
Old Apr 30, 2026 | 03:09 PM
red60R's Avatar
2017 C63S
Window Regulator?
Hey, what's up guys,
so was driving the other day with the windows cracked and went to put them up and the rear pax would not raise. I made mistake of cycling it and it would go down but not up. finally once all the way down I was stuck at a light and tried it and it went up. I thought. Was looking at the car today and realized there is a tiny space between the window and being fully closed. So I tried to raise with door switch. Nothing. Went to the actual door and tried that, nothing. I am guessing maybe the window regulator but open to other suggestions as to the culprit?
Old Apr 30, 2026 | 03:47 PM
superswiss's Avatar
2019 C63CS
There’s a procedure to reset the windows. Try that first.
https://www.google.com/search?smstk=...=sh/x/aio/m1/5
Old Apr 30, 2026 | 05:34 PM
red60R's Avatar
2017 C63S
I think that is for the fronts, with the auto down feature. I tried this but nothing happened. Now I did notice when I pull up (and even tried the other 3 windows), I hear a sound like something regulating but then when I do this rear pax window no action on the window. So I took a chance and went all the way down, which it did. I tried to go up, nothing. I tried to do down 10 seconds, up 10 seconds, nothing. Just when I was frustrated I went to the door itself and tried up and it powered right up and closed fully. Now, I don't want to touch anything. Still not sure what is wrong but at least the window is fully closed.
Old Apr 30, 2026 | 05:41 PM
superswiss's Avatar
2019 C63CS
Not sure if the reset procedure works for the rears, but it has to be done from the door itself. Sounds like you are doing it from the front door, am I right? Maybe the switch in the front door is malfunctioning if the window open/closes using the switch on the door itself.
Old May 1, 2026 | 07:22 AM
red60R's Avatar
2017 C63S
it's weird because earlier in the day, when I first saw it cracked, I tried the driver door, then went to the back door panel and tried to raise it with no success. I did NOT cycle it down or at that point know your 10 second procedure so no, I didn't try that on the door panel yet. Once I got it to come fully up yesterday I have not messed with it again.
Old May 1, 2026 | 10:46 PM
jj18's Avatar
2019 C63S Coupe
Old May 2, 2026 | 04:41 AM
jj18's Avatar
2019 C63S Coupe
Originally Posted by jj18
From Service Manuel.
Old May 2, 2026 | 04:42 AM
jj18's Avatar
2019 C63S Coupe
