Fixed Rear Windows...now BAS/ESP????
2002 CL500 W215
OK rear windows would not work, I finally found which fuses governed them and replaced them, even though they looked and tested fine, disconnected the battery but the new fuses in, connected the battery and they worked perfect!!
I start the car and I get 2 malfuntion warnings, BRAKE ASSIST ASB, and ESP (Visit workshop!). I am at a complete loss on how this happened, maybe the battery disconnect reconnect? any way to reset. My warrenty ran out 2 weeks ago and have had the car start falling apart almost the day of. I am starting to think there are timers on these things!! ahaha.
Any help is greatly apreciated.
Alex G
Alex G
Alex G
Alex G
Jud
real windows malfunction
Hi Alexgreggs,
Which relay or fuse did you change to fix your real window problem? I have exact the same problem on my 2002cl last week(this must have a timmer, my warranty expired on OCT)and I call in the MB roadside assistance and they told me to unplug the battery to get the windows up, and it did, and they also teach me how to reset the EPS by turning the wheels side to side. But after few minutes the window malfunctions again. Now I am not using the real windows at all. I notcie that it also has an effect on my sunroof, it will not operate automatically, I will have to hold the button to open or close it. I check the fuses and they are intact, I am pretty sure its one of the relay under the rear seats, can you tell me which relay did you change? and are they working after few tries?
tks
IH
tks
IH
1 Post
06' Clk 500 Cabriolet, 01' CL 55, 00' Clk 430
Originally Posted by ihcombo
Hi Alexgreggs,
I notcie that it also has an effect on my sunroof, it will not operate automatically, I will have to hold the button to open or close it. tks
IH
IH
When you disconnect the battery long enough, all the one-touch features like windows, sunroof...etc. will lost it memory. You would have to manually re-program these features again. It in your user's manual.
real window malfunction
OK great, it was easy to reset the sunroof.page 188 press the tilt button up and hold for 1 second.
But any know how to fix the real windows? its will only work 1 time after I disconnect the batter for about 1 mintues and it stop to work? is there fuse or relay that I can change?
http://www.startekinfo.com/StarTek/
It's not free, but perhaps you'll want to check it out. I understand it's quite good and used by many independant mechanics.
